clutch nut
  • mack
    • 2411
    • Ontario, Canada
    clutch nut
    Ok, so I'm trying to get the clutch apart but I can't get the nut off because the whole assembly turns. I've tried clamping the outside plates but then the whole engine turns over. What's the trick to getting this thing off?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    Air impact wrench will take that bad boy right off. The other way to do it is to put it in gear and have someone hold the rear brake on while you do it, or use a two by four in the rear wheel with it in gear, just don't try this on the side stand, or you might find it laying on it's side.
    I found the impact wrench to be the easiest and fastest way. One quick zap and it was off.
      Same way I put 'em on. Get your ratchet on it, then hit the handle with a rubber hammer hard.. that has always broke them loose for me when I didn't have an impact.
      • mack
        • 2411
        • Ontario, Canada
        Got iut
        Ok the impact driver worked great. Thanx.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
        • red bandit
          • 957
          • central michigan
          I'm glad you got your nut off.
          79 SF parts bike.
          • kirmit77
            • Mar 2009
            • 464
            • Kingwood, TX
            WOW........
            Austin Ingalls
            MIDNIGHT FURY
            1979 XS1100 Special [Full Restore Project]
            XJ maxim rear air shocks
            KERKER 4-into-1 exhaust
            Pod Filters
            Money pit.......
            BLACKED OUT
            • cycleguy
              • Dec 2009
              • 15
              • portage,wis.
              IF you use an impact to tighten your nut---be carefull---I pulled one apart that someone used impact on & stripped the nut! Use a torque wrench!!
