BDF Special
Are you looking for the owner's manual, or the service manual? Either way, you can download one (or both) from the link in my signature. I host a buch of those manuals on my website for a free download.
Thank You Catatonic Bug,
Your manual library is much appreciated.
I recently down loaded the shop manual and printed it.
While computer illeterate I managed to sort it all out with out even calling a friend or outside intervention. Adobe Reader is required on the computer to open the file for those of you equally challenged, it too is availabe free on the net (Google Adobe)
Maxim Phil
If you download a program like "Software 995", Also free, you can edit a PDF with it. Using that program you can then effectively cut a sheet out of a large PDF with the extract function. It will also combine more than one PDF file into one larger PDF file.
Or, you can get something like CutePDF (this link will download the file directly), which allows you to print ANYTHING to a pdf file. It's just a print driver, but when you "print" the document, it asks where you want to save the new file. All you need to do is "print" the one page (or selection of pages) to a new file. We use this program here at work on all the PC's, to help people save paper.
