Stripped brake bleeder screw 911
  • Korr
    • Jul 2008
    • 293
    • Torrance, CA
    Hi guys it's been awhile since i've posted. Hope everyone is having a good December. Just moved down south to Torrance. I finaly got some time to myself and tried to take the bike out for a spin, but my brakes pretty much locked. They've been spongy before the move, but are now so tight that i cannot even push the bike around in neutral. I just tried to bleed the brakes and replace the fluid, but i have amanaged to halway strip the right side bleeder. The left side feels like it will strip to if i keep forcing it. I am doing lefty loosy and righty tighty. Any tips, thoughts, questions, or ideas would be greatly appreciated. Thanks guys
    1978 XS1100E Standard
    Tkat Fork Brace
    On Hold
    TopCat S.O.F.A. + Fuse Block
    Mike's XS Pod FIlters
    PB Blaster...IS the threads stripping or your rounding off the hex head part of the bleeder?
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      When I bled my brakes for the first time, I thought they were going to strip on me, and I was almost ready to try the air impact on them, but as the last try before that I took the 6 point socket I was going to use with the impact wrench and put in on my torque wrench and did a reverse torque and they popped loose. Part of the secret is getting the best fit with a socket or box end wrench that you can, and you NEED 6 point or it will round them off.
      • Korr
        • Jul 2008
        • 293
        • Torrance, CA
        It's the hex edges. They almost all gone now on that left side.
        Tkat Fork Brace
        On Hold
        • XSokieSPECIAL
          • Jun 2009
          • 1631
          • Tulsa, OK
          Yup, what cy said. A good tight fitting 6 point is the ticket.
          Also try tapping on the top of the bleeder screw with a small hammer before you try to turn it, or while you trying if you have a 6 point box end wrench.
          You can also tap on the side of the caliper where the bleeder goes in while trying to turn it.
          • XSokieSPECIAL
            • Jun 2009
            • 1631
            • Tulsa, OK
            If it get's too rounded, take the caliper off and clamp the BLEEDER SCREW tightly in a vise and then turn the caliper, unscrew the caliper from the bleeder.
            I've had to do that a few times with auto calipers.
            • Korr
              • Jul 2008
              • 293
              • Torrance, CA
              Thankyou for that injection of common sense. Brakes work good now
              Tkat Fork Brace
              On Hold
              • Incubus
                • 1003
                • Austin TX
                FWIW, unlike my Hondas, the bleeder screws on an XS11 are a pretty common metric size and pitch. I got replacements at Auto Zone for like a buck each.
                Patrick
                XS11F (Incubus, daily rider)
                1969 Yamaha DT1B
                  Patrick
                  Good to know... My local Yamastealer wanted over $11 EACH for those things!
