I guess I just put off the fix on the 2 gear too long that now it finally bit me in the @$$. On friday after work, I deposited my check at the bank and headed home. Did not get 1 block before my tranny got stuck in neutral and when i almost came to a stop it started making a grinding noise. Found out one problem so far.....
First of all here is a pic of my bike for those.... pretty much everyone who has not seen a finished product
![](http://i263.photobucket.com/albums/ii139/kirmit77/Snow%20and%20Trans%20Break%20down/Photo0148.jpg)
ok so the shifter shaft doohickie came out.... and it would not shift into another gear....
This is what it is not supposed to do.... Notice about the center of the picture there is a shaft showing.... not supposed to when i pull off the cover
![](http://i263.photobucket.com/albums/ii139/kirmit77/Snow%20and%20Trans%20Break%20down/Photo0168.jpg)
Look in the middle of the cover and see where it had been rubbing
![](http://i263.photobucket.com/albums/ii139/kirmit77/Snow%20and%20Trans%20Break%20down/Photo0174.jpg)
Now when I pulled the clutch off a little gear fell down.....
![](http://i263.photobucket.com/albums/ii139/kirmit77/Snow%20and%20Trans%20Break%20down/Photo0176-1.jpg)
Not good.... everything on the doner engine looks to be good
the bad thing is i found metal shavings, 2 washers, and a circlip in my pan
ALSO look at my header....
![](http://i263.photobucket.com/albums/ii139/kirmit77/Snow%20and%20Trans%20Break%20down/Photo0160.jpg)
Lots and lots of work to do this week.... LOTS
more pictures to come tommorow
