Dot 5 (Silicone) brake fluid?
  • Tropic-al
    • Nov 2009
    • 175
    • Tampa, Florida
    Does anyone have pros/cons to using Dot 5 brake fluid in the 11's?
    I was told not to do it because it COULD cause a problem in the old aluminum brake calipers.
    I changed the rear fluid to Dot 5 and after about 300 miles, while on a ride, the caliper would not release, thus overheating and locking up. After it cooled off (?) it loosened up and I rode it back home without using the rear brake. Putting it on the center stand, turning the wheel by hand and pressing the lever it seemed to work normaly. Then I kept some pressure on the lever and it went down like the pedal would in a car when your master cilinder goes bad.
    Any ideas? Think it has something to do with the Dot 5 or just a coincidence?
    79 XS1100F.
    TC's fuse box.
    SOFA filter.
    Venture cam chain adjuster.
    Tkat fork brace.
    Progressive fork springs.
  • tarzan
    • 1700
    • Chandler,Az.
    I use dot 5.It supercedes the older stuff and it is the only grade available here.
    I would bet you need to disassemble and clean calipers and masters.
    As far losing pedal,that is probably like you thought, the master needs a rebuild.
    80 SG XS1100
    14 Victory Cross Country
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      DOT 5 is not compatible with DOT 3. The complete system needs to be disassembled and cleaned of all traces of DOT 3 (including the inside of the brake hose(s) ).
      Even then vintage parts, like NOS hoses and rebuild kits, may react negatively to DOT 5.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • XSokieSPECIAL
        • Jun 2009
        • 1631
        • Tulsa, OK
        This might be interesting reading for you Tropic-al..........
        • Tropic-al
          • Nov 2009
          • 175
          • Tampa, Florida
          My bad !!!
          Thanks Tarzan.
          Just FYI, dot 5.1 is not silicone based, so its safe to use. Dot 5 is, and apparently it is what causes the problem.
          Thanks Pat.
          I definitely did not do a thorough cleaning of all the dot 3 fluid like you mentioned. I should have heeded the warning about it possibly affecting the aluminum calipers.
          I guess a rebuild of M/C and caliper is in order. For sure I'll use dot 3 or 4.
          79 XS1100F.
          TC's fuse box.
          SOFA filter.
          Tkat fork brace.
            There is an article in either the tech tips or the FAQ about the isue of DOT 5 and DOT 3 or DOT 4 fluids. The issue appears to be more of combining the two types of fluid. Like PAT stated, the two fluids will not play nice together so you need to get all of the old out before adding the new.
            I am no expert and certainly do not know for sure, but I doubt there is any issue with the fluid and the metals involved. The rubber even seems unlikely to be an issue. JMHO
            • petejw
              • 2269
              • sydney australia
              You should be sweet in flushing the system out with
              dot 3, i doubt you would need to rebuild the calipers or m/c,
              the fluids dont mix together, but it shouldnt effect
              any of the rubbers.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • Tropic-al
                • Nov 2009
                • 175
                • Tampa, Florida
                Thanks XSokie
                Enlightening article.
                Another learning experience!!
                79 XS1100F.
                TC's fuse box.
                SOFA filter.
                Tkat fork brace.
                • XSokieSPECIAL
                  • Jun 2009
                  • 1631
                  • Tulsa, OK
                  Welcome....... bottom line is standard dot 3/4 fluid is really all you need. The dot 5.1 has a higher boiling point but is not neccesary in our application.
                  Just flush it every couple of years. Your hydraulics will last virtually forever.
                  Dot 5 if you run NASCAR and want to replace it A LOT!
                  Postal vehicles used to run dot 5 because of thier stop and go life but it was changed at regular intervals.
                  Your tax dollars at work. Not to mention the price of stamps.
                  • cywelchjr
                    XS-XJ Super Guru(Deceased)
                    • 4450
                    • Sacramento, CA
                    I'm not sure, I have DOT 4 in mine, and when the temps are over 115 in situations with lots of stop and go the brakes will go spongy on me.
                    I'm not so sure about that. After reading the owners manual this week, Yamaha says all seals should be replaced at least every 2 years, and the flexible lines should be replaced at least every 4 years. I know that they seem to be doing ok (no leaks and all) but then I suspect mine was bled regularly, but according to the schedule all the seals should have been replace 14 times by now and the flex lines 7 times, and I'm pretty sure that at least the flexible lines are the originals, I plan on doing something about that before summer gets here, and since I run sintered pads, I'll probably go with DOT 5.1 for the higher boiling point.
                    Have spent 7 years in the Army I'm not only not surprised, I'm almost shocked that they didn't replace the entire brake system each time they did it.
                      • 3192
                      This is what it looks like when you mix Dot 5 and Dot 3. I mixed in more Dot 3 and it went back to fluid state for a while. I did not get around to changing the brake system yet and now it is looking sorta like pudding.
                      • XSokieSPECIAL
                        • Jun 2009
                        • 1631
                        • Tulsa, OK
                        I don't think that will be because of brake fluid boil cy. Most likely some runout in the rotor due to heat, pushing the piston back in a little further than usual. That rotor would pretty much have to be glowing red to boil the brake fluid in that extremely well ventilated caliper.
                        I'm sure Yamaha enjoyed selling parts. Henry Ford did too.
                        That is why he sold the Model T so cheap. He knew he would make his money back on parts.
                        Truth is motocycle brake parts are no more susceptible to damage than automobile brake parts.
                        IF they are properly maintained.
                        Dot 5.1 is unquestionably superior to dot 3/4 as far as temp. goes but IMHO unnessesary.
                        • XSokieSPECIAL
                          • Jun 2009
                          • 1631
                          • Tulsa, OK
                          OOPS!!!!
                            • 3192
                            OOPS!!!!
                            I did not do it but yup thats an oops. Kinda interesting to watch it change over the weeks. Once I get new S/S brake lines for that bike I will be rebuilding everything from brake handle to speed bleeders. Still have to finish up the 78E I have apart first as well so I will get to see more changes. I have left the lid loose so it changes more rapidly.
                            • wa407mpp
                              • Jul 2007
                              • 717
                              Brake fluid is rated by boiling it's point, the higher the boiling point the higher the number, but also the higher the boiling point the quicker it will absorb moisture. That is why it is usually reserved for hard use applications.
                              Fastmover
                              lion". SHL
                              78 XS1100e
