FJ1100 fork conversion
    • 8800
    Mod completed
    This mod took a lot of time and hard work, but the end result was well worth it. This bike is soooo much fun to ride now. She'll take turns now with lightning fast response, and the ride can be dialed in to suit your riding style in a matter of seconds. Total cost, not including tools, about $150.
    07 Triumph Tiger 1050
      Very nice Mod Phil!!! Awesome job making the parts to!
      Now if it only had a front fender (I know, dang engineer sweating the finer details.)
        • 8800
        Thanks man, I was test riding in the rain a bit yesterday, the water comes right up off the road and hits you square in the face. I'm gonna try to incorporate the XS fender onto the fork brace somehow, maybe shorten it a little. The bike rides friggin' awesome, the wider stance helps tremendously.
          When you have a chance, I'd love to see some more overall pics with the new look.
          • 81xsproject
            • 3185
            • Fortuna, CA
            Are these forks larger diameter? otherwise, I am not sure I see the real benefit beyond better dampening, which, at $150 you could afford emulators. What about fork angle? I really like this mod as it allows retention of the stock wheel.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
              • 8800
              These fork tubes are 41MM diameter, and are further apart from each other in the triple trees. Stock XS forks are 37mm, but I'm sure you know that. The fork angle is the same or just slightly less than stock. The fork legs have to be bored out to 17mm to retain the stock wheel. The FJ fork uses a 15mm axle. A 15X47X14 wheel bearing does exist, but is rare and hard to get. I'll have some more pics shortly.
                • 8800
                couple more pics
                I'm waiting for the fork brace piece to be sent from Miami, then I'll start figuring out how to mount the fender. These forks are slightly shorter than the XS's, but don't need to compress as far in travel to operate. They lower the bike just the perfect amount.
                  Awesome job Phil. If no one told you, you'd think they were stock till you realized they sit a couple inches shorter. Looks like a runner for sure!!
                  • petejw
                    • 2269
                    • sydney australia
                    Youve done a really good job there Phil,
                    the ride height looks sweet too.
                    must of missed it somewhere,
                    but how did u go about drilling the forks for the axle?
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    1981 xs1100 RH (aus) (5N5)
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                      • 8800
                      I drilled them out in 3 steps with a cheapo benchtop drill press. 5/8" first, then 21/32", last a 17mm bit. It went pretty smooth. If I was to do it again, I'd either use a hone or take them to a pro.
                      Now I'm having problems with the damping circuit on one fork, so I have to build a tool to dismantle them next.
                      • jmnjrpa
                        • Jun 2009
                        • 863
                        • Lewisville, Texas
                        They look good. I just can't understand how they are supposed to stiffen the forks?
                        '81 1100 MNS - "Midnight XSpress"
                        Original except:
                        Big John
                          • 8800
                          Larger diameter fork tubes + further spacing apart from each other = more stability, less fork flex.
                          I just got done disassembling the forks themselves and found that the PO had put them together improperly. The two forks were damping at different rates which resulted in a shimmy when cornering. I believe I got it all sorted out. Time for a test ride again. Nice thing about these FJ forks is that all the bushings and most of the internal parts are still available, for now.
                            • 8800
                            OK, got the fork brace today and installed it with some nuts as spacers to raise it up to about 8MM above the tire. Gonna get goin' now on chopping the original fender mounts down and adapting them to fit the fork brace mounting holes. The fender will sit over the brace hiding it. Some more pics....
                            • Cobia
                              • Jul 2007
                              • 1587
                              • Palm Beach County, Fl
                              Looks tight
                              Phil,
                              The bike looks really tight, kind of gathers it all in. Knowing your skills, I know you'll have no problems modifying the fender. Question though, I don't see any dust caps/seals on top of the lower portion of the forks?? Does it use them? Missing??
                              Overall, great job, hope the ride is as good and you can get over those internal problems soon.
                              1980G Standard, Restored
                              Kerker 4 - 1
                              850 Rear End Mod
                              Automatic CCT
                              1980GH Special, Restored
                              '82 XJ1100 (Sold)
                                • 8800
                                Yep Robert, they were missing when I got the forks. The oil seals are fine tho. Those dust wipers will be last on my list of things to do. Now I gotta fix the leak in the 750 FD. Might as well put on my new rear tire when it's apart.
