Parts are finally starting to trickle in for the build, and I am trying to get as much done as I can in hopes of finishing before summer. So here is, the beggining of The Juggy.
The plan is a frame up budget build, but still custom and sporty. Then once its rideable, then I can really start polishing it up and making a nice final product.
2002 Hayabusa forks and monoshock
Dirt bars
2003 FJR1300 swingarm/final drive
79(I think) XS1100F tank
Hydraulic clutch conversion with Brembo radial MC
Dual stainless mufflers
Solid engine mounts
Possibly a Ducati 996/998 tail
7" round front headlight
Possibly a cafe fairing
More as I go.
'81 Titled frame (yes, its in my living room)
Untitled engine and electrical donor. Supposedly had a rebuild that wasnt paid for and it sat at the shop for a while. Has good compression all around, so Im going to check it out, but hope for the best. Needs carbs. The clutch cover is with my machinist getting fitted for a Ducati slave cylinder, since I already have spares of these for my FZR. I need the timing cover and flywheel covers though.
Ive got a whole bunch of parts showing up on monday, my Busa forks, tank, and I think the shock. And tues or wed my complete swingarm and exhaust will be here and then I can really get started.
More to come as I make progress. Comments? Suggestions?
Dirt bars
Solid engine mounts
More as I go.
The dog isnt a big fan though.
This means a longer wheelbase as well for more stability and comfort on long sweeping roads, not that brilliant in hairpins however... maybe it will work out fine with the shorter forks.
