My XS11 Project - Juggernaut
  • Athedra
    • Oct 2009
    • 221
    • Benoni, South Africa
    Cannot say forsure, but the rear wheel specs is about what I have on Bones, with as far as I know a standard swingarm with a 750FD.
    Bones is in the workshop, will let you know tomorrow
    '79 XS1100 (2H9) named Bones
    1196 Big Bore
    4-1 Cowley exhaust
    750FD Conversion
    Echlin 54mm Racing Cones (Americanese = pods)
    Black Ebony Bottled glazed Tank (To be redone now)
    BMX footpegs
    Tank internally lined (Professionally this time)
    GSX400 Throttle bodies (Under serious investigation)
    Anti Sticky float bowl system
    • MrFreeze5
      • Aug 2009
      • 138
      • Denver, CO
      Today was a big day for the parts fairy. got my complete swingarm and assorted bits, Busa shock, tank, and busa forks. Suprisingly, the busa forks are even shorter than the R1 forks are by about 1-1/4", this is going to really lower this thing. Hope its not too much. Now that I can actually look at the tank, I LOVE it, I really like the color too. Kind of a gun metal blue metallic. I dont think the monoshock fabrication will be as bad as I originally expected, but the swingarm pivot mount is going to be a pain.
      1981 XS11SH Custom Project - Juggernaut
      1990 FZR600 Hybrid Streetfighter - Lilith
      1996 FZR600 Custom Project
      1994 FZR600
      • Mathh
        • Nov 2006
        • 699
        • Beek, Netherlands
        Originally posted by MrFreeze5
        ...... but the swingarm pivot mount is going to be a pain.
        Naahhh, it's not a pain, just a bit of welding and making a one off axle.
        You have to weld in a vertical plate between the u-joint and the left swingarm bearing. I'll have a look if I have some pictures..
        MV Agusta Brutale 910R '06.
        Yamaha MT-09 Tracer '15 grey.
        • MrFreeze5
          • Aug 2009
          • 138
          • Denver, CO
          Ive actually got a several pics of your setup saved already. I dont see it as being overly difficult, just time consuming.
          One question though, did you cut down the swingarm at the pivot tube on either side or have any centering issues?
          1994 FZR600
          • Athedra
            • Oct 2009
            • 221
            Probably a dumb question
            The shaft on the new swing arm, is it directly compatible with the XS or do you have to fit a different type of CV-yoke in there?
            Nother question that got into my head. Wouldn't a 17 Litre teardrop tank go better with the conversion?
            1196 Big Bore
            4-1 Cowley exhaust
            750FD Conversion
            BMX footpegs
            • MrFreeze5
              • Aug 2009
              • 138
              • Denver, CO
              The yokes interchange from what i understand, but I have not checked yet.
              A teardrop tank wouldnt look right with the tail I want to use. When I saw this one, it spoke to me. Its definitely the right tank for this build.
              1994 FZR600
              • Mathh
                • Nov 2006
                • 699
                • Beek, Netherlands
                Can't remember and as the swingarm has been powdercoated i can't check. Send me some pics from the sides of your swingarm and i will compare them with mine.. And the stock FJR shaft fits one on one to the XS without a single mod. That is if you keep the standard XS swingarm pivot.
                • MrFreeze5
                  • Aug 2009
                  • 138
                  • Denver, CO
                  Ill snap some closer pics, but from the looks of the pics I have of your ride, it doesnt look like it was modified. And if it was, it would have been a somewhat involved process since there really isnt much material that can be removed. Its just been kind of a PITA to try and find the centerline on this asymmetrical swingarm without having a wheel on hand yet. I think Ive got it pretty close and I dont think any swingarm modding would be necessary. I am really surprised at how close everything seems to fit. Its should be pretty straightforward as far as the frame mods go, and the monoshock conversion is 10x easier than i expected it to be, but I will still probably overbuild it.
                  1994 FZR600
                  • MrFreeze5
                    • Aug 2009
                    • 138
                    • Denver, CO
                    There are casting marks on my swingarm around the bearing cup on the pivot tubes, round and square marks. They are 3/8" from the edge of the casting marks to the outside edge of the swingarm pivot on both sides. If yours has the same marks, it would be a good reference point.
                    These are the only pics Ive got at the moment, Ill try to snap some closer ones later.
                    1994 FZR600
                    • MrFreeze5
                      • Aug 2009
                      • 138
                      • Denver, CO
                      Here's a nice little bonus. I bought a Ducati Monster clutch system for the slave cylinder and stainless line it had to use on my FZR hydro clutch conversion. Got a good deal on it too, but the whole thing came with a master cylinder too. I already have a few Yamaha slave cylinders for the XS11 hydro clutch conversion, and my stock clutch cover is at the machinist to have a new one made to mount the slave to. This master cylinder is a Brembo and although it is simple, its essentially free for this build and will match the Hayabus brake MC I need to use with the 6 pot calipers until I can afford aftermarket radials. Eventually, I am going to use a radial clutch MC just like I have for my FZR. Its from an Aprilia and it is oh so sexy, but for the purposes of functionality, Ill use what i have to get it going.
                      1994 FZR600
                      • MrFreeze5
                        • Aug 2009
                        • 138
                        • Denver, CO
                        Got the exhaust today and it looks great. Did a little mockup, me likey. Theres another can for the other side, but i ran out of zip ties
                        1994 FZR600
                        • TomRodgers
                          • Jun 2008
                          • 492
                          • La Porte Indiana
                          Looking good so far!!! but somehow i dont think you are going to get very good cornering or milage out of that front "tire" there.....not even if you put its mate with it
                          Betcha that living room is about 60-70 degrees warmer than my garage (im
                          jealous....SWMBO would string me up by my tight curlies if i tried doing that!!!_
                          '81H (my first XS ) "Grey Ghost"
                          4:1 Jardine w/ headerwrap
                          Windjammer(wiring issues)
                          New paint/brakes to come!!
                          '80G FrankenBike (parts bike)
                          '80G to fix "BlackSunshine"
                          Stock Pilots/125 mains
                          Pod filters; 4:1 Kerker??
                          SS Brake lines w/ new M/C's
                          LED Brake Lite
                          Needs paint....
                          • XSokieSPECIAL
                            • Jun 2009
                            • 1631
                            • Tulsa, OK
                            Das Boot(s)
                              That looks like a NICE conversion!! My only thought is the swingarm is in the "compressed" position, correct?? The front and rear axles should be about the same height off the floor, I think. The tire diameter from front and rear should only be about 2" off. The front forks put the axle almost on the floor, and the rear is up about 6". The mount for the shock should be closer to the rear tubes, not the front ones. JMHO
                              Again, LOOKING GOOD!!
                              • MrFreeze5
                                • Aug 2009
                                • 138
                                • Denver, CO
                                Its all just mocked up right now to get a visual for the fabrication necessary, which I will probably get started on next week. The rear is higher because thats as low as I could get it with a sideways jackstand. I need to get a rear wheel before I can do any final work though since the swingarm is asymmetrical Im not sure exactly where the centerline is. So once I have the wheels I can work out ride height amd suspension tab position. the front forks wil lower the bike quite a bit, so I will more than likely have a new upper triple tree made to give me a little extra height out of it so i dont have clearance problems. I need to drop the rear too, and can evaluate that once I have the seat in place I am going to use.
                                1994 FZR600
