Mysteries of Mikuni CV carbs revealed
  • dbeardslee
    • 4385
    • Maineville, OH
    So have you ever wondered exactly where the gas and air go after they enter your carbs? Steppenwolf recently posted a link on the SWOXS social group page that contained a bunch of Suzuki manuals. One of them was for Mikuni BS 32 carbs, and even though ours are BS 34's, much of the information is relevant. I was fascinated by the cross sectional diagrams that show exactly how the fuel and air flow inside our carbs. Check it out - Mikuni BS32SS
  • oseaghdha
    • 1075
    • N43.02.5,W88.14.2
    I think the best part is where they show how to properly set the float height.
    XS1100SF
    XS1100F
      • 8963
      Good stuff.
      • XSokieSPECIAL
        • Jun 2009
        • 1631
        • Tulsa, OK
        Originally posted by dbeardslee
        plastic floats - 25.5mm
        I had to set my brass floats on my 79 carbs at 27.5 to keep them from running INCREDIBLY rich. It seems the way instructed here would make them adjusted WAY higher with the spring loaded float valve needles.
        FLOAT HEIGHT ADJUSTMENT
        @ TO check the float height, invert the carburetor
        body. With the float arm kept free, measure the
        height @ while float arm is just in contact with
        needle valve by using the caliper. Bend the
        tongue O as necessary to bring the height @ to
        this value.
        NOTE:
        Be sure to remove the gasket before meas-
        Float height @
        The value of float adjustment being 22.4mm
        JAT
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          That's why my scoot doesn't run right, I didn't use a torque wrench on the bowl screws...
          Ich habe dich nicht gefragt.
            I don't care HOW many pics you wanna post. It all comes down to the truth in the long run. They're MAGIC!
            • cywelchjr
              XS-XJ Super Guru(Deceased)
              • 4450
              • Sacramento, CA
              Darn! I didn't either, but apparently the PO used pliers on them. I can't really say I blame him/her, I did the same on my 400, but then I recently got replacement ones and now I use ONLY the proper size wrench (I carry it in the saddlebags along with the other likely to be needed on the side of the road tools (socket and ratchet for removing the seat etc.)
                And black voodoo magic at that!!!
