Clogged starter jet
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    Clogged starter jet
    Cleaning carbs and having a bugger of a time trying to clean out the holes in the float bowl.
    Studying the tips and threads I believe its called the starter jet and leads to the choke circuit.
    Its just one of them that I cannot get clear.
    Anyone have a similar experience?
    Any suggestions would be appreciated
    Rick
    650SF
    XS1100SG Project bike
    Yep, they can be tough sometimes to clear. PB Blaster, a guitar string, and a little patience is what I use to get the passage clear, then spray some carb cleaner thru.
    • Rickrod3
      • Jun 2009
      • 721
      Thanks
      I'll give that a Try
      Happy turkey Day
      650SF
      • Cobia
        • Jul 2007
        • 1587
        • Palm Beach County, Fl
        I agree with Phil. I've had to let them soak for several days poking at the passage with the guitar string a several times every day. Be patient and persistent, eventually it will clear up for you.
        1980G Standard, Restored
        Kerker 4 - 1
        850 Rear End Mod
        Automatic CCT
        1980GH Special, Restored
        '82 XJ1100 (Sold)
          I use a fine sewing needle.
          • Athedra
            • Oct 2009
            • 221
            • Benoni, South Africa
            Guitar String and a good air pressure clears it right up. Once the air goes thru, just pump some high pressure air and carb cleaner thru it. Clears out nicely.
            '79 XS1100 (2H9) named Bones
            1196 Big Bore
            4-1 Cowley exhaust
            750FD Conversion
            Echlin 54mm Racing Cones (Americanese = pods)
            Black Ebony Bottled glazed Tank (To be redone now)
            BMX footpegs
            Tank internally lined (Professionally this time)
            GSX400 Throttle bodies (Under serious investigation)
            Anti Sticky float bowl system
            • latexeses
              • Jun 2008
              • 1491
              • California
              Rickrod3,
              If you can lay your hands on a sonic cleaner, do so. I went through the first carb on my SF and was sure I did a good job. Put the parts in the cleaner and turn it on. Solution looked like I tossed in a charcoal briquet. The ammount of crud that was still in there after all the Gumout, soaking and scrubbing was shocking. I have cleaned plenty of auto carbs and thought they were clean too but at that point I wasn't so sure. From now on that is going to be the "last step" when I am cleaning carbs.
              I used a mix of Dawn dish soap and Simple Green for the cleaner solution.
              Everything on hold...
                Originally posted by Athedra
                ...good air pressure clears it right up. Once the air goes thru, just pump some high pressure air and carb cleaner thru it.
                Only one word of caution - be sure to wear some eye protection when you do this. Once if finally breaks through, it will spray an amazing distance!
