timing light
  • GARTHXS
    • Nov 2007
    • 1631
    • Seattle
    timing light
    so Im in the market for a timing light , just wondering what kind I should get and where is the best place to get one??
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
  • oseaghdha
    • Aug 2006
    • 1075
    • N43.02.5,W88.14.2
    Get a dial back type with inductive pickup.
    I think I got my Sunpro at Sears, don't remember, but it works great.
    XS1100SF
    XS1100F
    • GARTHXS
      • Nov 2007
      • 1631
      • Seattle
      how much
      Did it cost?
      91 kwaka kz1000p
      Stock
        Originally posted by garthxs
        so I'm in the market for a timing light , just wondering what kind I should get and where is the best place to get one??
        Ebay. There's been more than a few high-end tools for sale (what with the bad economy) pretty cheaply. Snap-on, Mac, Matco all make heavy-duty models that will take a bit more bashing around compared to the less expensive 'consumer' models and right now for about the same money if you do a bit of shopping.
        '78E original owner
        • GARTHXS
          • Nov 2007
          • 1631
          • Seattle
          thats a good idea
          But I really want to get something local, kragen, autozone, sears,walmart, and inexpensive not cheap
          91 kwaka kz1000p
          Stock
            I picked up a cheap model that works just fine from Freight Harbor for like $15. Yeah it's kinda cheaply made, but for the price if it works just one more time I'm fine. The cheapest I could find after that was like $40 at the auto parts stores. Just can't see spending more for the very very few times I will use it.
            • Montreux_Blue
              XS-XJ Guru (Deceased)
              • 1143
              If you want accuracy from 0 to 8,000 rpm then find an old Sears Craftsman(P/N A-2134) or MSD (P/N 8990). I got one of the old Craftsman 2134 off ebay a couple years ago for about $20.
              Famous Myspace quote:
                I use this one, had it for a few years now with no problems...
                http://www.harborfreight.com/cpi/cta...emnumber=40963
                • dbeardslee
                  • Nov 2007
                  • 4385
                  • Maineville, OH
                  I've got your basic timing light, which works fine for doing your basic timing. I've been looking at a digital Actron light, primarily for the tachometer function. Been wanting to try a tach for setting the carbs, but as previously stated, when you get more bells and whistles the price rises accordingly. I've found Tooltopia.com to be an excellent place to get tools, but the actron timing lights are available in most auto parts stores if you prefer to by local - you'll probably pay more, though.
                    Harbor Freight also has an rpm gauge that you would just press against the timing plate (at the center) to read the RPM, I may get one in the next month or so, it looks like it will work just fine for what I need it for. It's still cheaper than the cheapest timing light at Auto Zone and both the timing light and the RPM meter are cheaper by far than the timing light with RPM function. I figure I don't mind several tools to do the job as long as they work. HF has both a mechanical (Presses against the center of the spinning wheel) and light actuated (just point at the edge and I guess it figures out when the same point comes back by) units, I figure the mechanical actuated one will work fine for me and save about $25.
