XJ1100 carbs
  • Lunatic
    • May 2006
    • 200
    • Watertown SD
    XJ1100 carbs
    Do XJ1100 carbs bolt on in place of XS1100 carbs, or is there a diameter or spacing difference?
    • 8930
    Same spacing, they'll fit. The XJ carbs have no choke lever, but it can be swapped IIRC from the XS bank.
    • XJOK2PLAY
      • 2099
      • Skiatook, Ok.
      Yep... the main differences are the way the choke is... XJ's used a cable controlled choke lever from the left handlebar. Only other differences are mainly in the jetting internally.... a lot smaller thanks to those lousy emiisions laws they had back then...
      I'm thinking the throttle hooks up the same... cable in the center.
      If one was to put them on an XS w/o doing any rejetting... they may not like the way it ran, though.
      2011 Kaw Concours 14 ABS
        Depends what year XS he has (would be nice if it were in the signature...hint..hint...hint..hint!!) For the 81 model year I think the jetting is the same as XJ...110 mains across the board and IIRC they all used 42.5 pilot jets stock.
          • 8930
          XJ carbs, 47.5 pilot is stock. The float level is supposed to be measured with the tube level method also.
          • TomRodgers
            • Jun 2008
            • 492
            • La Porte Indiana
            81's had 42.5's and 110's as stated. The others will chime in with more technical info, but if the shoe fits, steal it. just be wary of running lean. Tootsie will get a little hot!!! NFG!!!
            4:1 Jardine w/ headerwrap
            Windjammer(wiring issues)
            New paint/brakes to come!!
            '80G FrankenBike (parts bike)
            '80G to fix "BlackSunshine"
            Stock Pilots/125 mains
            Pod filters; 4:1 Kerker??
            SS Brake lines w/ new M/C's
            LED Brake Lite
            Needs paint....
              Yup.. the XJ uses 47.5 pilots and 112.5 mains, but I ran a set from an XS once that had the 110 mains to see if the problem I was having was carb or electrical. I never felt any difference between the two sets.
              As also stated, you need to swap the rod on the front of the carbs that operates the enrichener (Choke) circuit. The rods are different lengths. Be carefull when disassembling this rod. It's a good idea to do the process in a big box if possible, but not needed if carefull. There are some spring loaded tiny steel balls that can shoot off into the 4th dimension. These are what makes the rod click into the different settings on the XS.
