Oh! I wanted to add something. I have seen a few XSs on here that are running "FZR" forks as upgrade. All the ones I saw like that were UK bikes. And in the UK, the FZR600 is the same as the UZ YZF600. The FZR600 has completely non adjsutable forks and 2 piston calipers and a 3" front wheel, the YZF has adjustable forks and 4 piston calipers and a 3.5" wheel. The US FZR forks would be a poor choice for the XS IMO. Keep that in mind if looking at these forks. I THINK the FZR and the XS use the same stem bearings though, I will have to double check. And the YZF600 forks are a direct bolt on for the FZR, so that should make the swap pretty simple if thats the case. I will look and try to verify that though.
Front fork upgrade??
Anybody running these? If so, what do you think?Not cheap, but I have been told by some I trust that the cartridge emulator is the hot ticket for the vintage bike.
That should be coupled with straight rate springs based on the weight of the motorcycle and rider.
http://www.traxxion.com/
I checked the website. About $170 (for one fork or both, I don't know). Even if this is per fork, I don't think this would be all that bad if it really improved handling. Or am I looking at the wrong thing?Happy Riding
1981 XS11 Special
2007 Moto Guzzi Norge
Oh yeah--and a blue 1960 Impala Sport CoupeComment
OK, another question: where are folks coming up with these pieces and parts? Scrap yards? I'm not in the middle of nowhere, but I can see it from here...makes finding parts kind of hard.Oh! I wanted to add something. I have seen a few XSs on here that are running "FZR" forks as upgrade. All the ones I saw like that were UK bikes. And in the UK, the FZR600 is the same as the UZ YZF600. The FZR600 has completely non adjsutable forks and 2 piston calipers and a 3" front wheel, the YZF has adjustable forks and 4 piston calipers and a 3.5" wheel. The US FZR forks would be a poor choice for the XS IMO. Keep that in mind if looking at these forks. I THINK the FZR and the XS use the same stem bearings though, I will have to double check. And the YZF600 forks are a direct bolt on for the FZR, so that should make the swap pretty simple if thats the case. I will look and try to verify that though.Happy Riding
1981 XS11 Special
ebay or bike specific forums.
All FZRs 400-1000 and YZFs(not YZF-Rs) have a 17mm lower stem and 15mm upper. Should be simple enough for bearings. It will likely need some sort of spacer on the stem, the FZR/YZF stems are longer than the XS.
So as long as you can find the right ID bearings to fit, your halfway there.
Ill have more info on the R1 setup this week. Im picking up a 01 R1 triple tree for my mockup forks tuesday. Dont know when the 06 stuff will be here, but itll probably be next week due to the holiday.Last edited by MrFreeze5; 11-22-2009, 04:55 PM.1981 XS11SH Custom Project - Juggernaut
1990 FZR600 Hybrid Streetfighter - Lilith
1996 FZR600 Custom Project
1994 FZR600Comment
I have a set in another bike (non-Yammy) and they work well. But would I buy them again? Nooooo....
They're expensive, and the adjustment process will try your patience. You have to physically remove them to do adjustments, and that's a messy deal. Granted, once you have them 'tuned' you're done unless you change the bike/setup, but still...
And RaceTech recommends straight-rate springs with the emulators, but after using 'their' setup, I removed the straight-rates and installed Progressives. No noticeable loss of handling, and much less harsh at lower speeds.
One other point; these bikes have rather undersized forks for their size/weight, so before I spent a lot of money trying to make them work like modern forks, I'd just replace them WITH modern forks.
'78E original ownerFast, Cheap, Reliable... Pick any two
