searched but maybe someone has done this already
  • jwhughes3
    • 2798
    • Home of the Alamo
    Has anyone adapted an XS750 (77-78) double seat for the XS1100 (1980)? I have found a nice custom XS750 seat and wanted to know if it is possible - or should I just forget it - I understand I will likely have to move the mounting brackets, just want to know how hard it is and what is involved.
    John in San Antonio
    Thanks in advance....
    '81 XS1100H - "Enterprise"
  • Athedra
    • Oct 2009
    • 221
    • Benoni, South Africa
    instead of moving, add some flat bar with slotted holes from the original mountings to the new. That way you dont damage the frame, and can always go back original when you want or have to.
    '79 XS1100 (2H9) named Bones
    1196 Big Bore
    4-1 Cowley exhaust
    750FD Conversion
    Echlin 54mm Racing Cones (Americanese = pods)
    Black Ebony Bottled glazed Tank (To be redone now)
    BMX footpegs
    Tank internally lined (Professionally this time)
    GSX400 Throttle bodies (Under serious investigation)
    Anti Sticky float bowl system
    • Athedra
      • Oct 2009
      • 221
      That is if it is not a direct fit.
      I have this thing about cutting and welding onto an original frame......Sorry
      1196 Big Bore
      4-1 Cowley exhaust
      750FD Conversion
      BMX footpegs
        • 1914
        I have not made a close comparison of the differences of the two seats. Is it possible that you could just strip the cover and padding from the 750 seat and then refit/reshape it to an 1100 seat pan? Just a thought.
        • jwhughes3
          • 2798
          • Home of the Alamo
          not likely...
          this is a custom hydrogel seat with an integrated backrest - I would be afraid that changing the pan would ruin the seat. I will think about using the flat bar stock - it is about $300 seat so I am a little leery of buying it without knowing someone has successfully made the conversion - but it sounds very comfy!
          John
          • Athedra
            • Oct 2009
            • 221
            John
            Hear what you are saying. Someone recently purchased a Corbin seat for $149 on e-bay. Have a look at what is available there before you go the other route. I liked the image I saw of the Corbin so much that I took it to a local upholsterer to see if he can make my stock seat similar. Maybe the Corbin grabs your attention too.
            1196 Big Bore
            4-1 Cowley exhaust
            750FD Conversion
            BMX footpegs
            • jwhughes3
              • 2798
              • Home of the Alamo
              looks like a corbin...
              but has the integrated backrest that switches for driver or passenger as needed - that plus the hydrogel - I am not opposed to spending the $300 to fix 2 problems (backrest for pass + long ride comfort) but hate to wind up trying to resell it to a triple owner if it wont work - I don't see why I cant make it work - the 2 frames can't be THAT different!
              John
              • jwhughes3
                • 2798
                • Home of the Alamo
                here are pics...
                looks like a corbin but isn't....
                Billions of happy photos, millions of passionate customers. Gorgeous online photo albums. Protect your priceless memories. Buy beautiful prints & gifts.
                underside:
                John in San Antonio
                  John in San Antonio
                  Hi John,
                  it ain't a drop-on, that's for sure.
                  The XS750 seat has hinges on the right side and a latch on the left.
                  The XS11 seat has a tongue at the front and bolt-downs on each side.
                  Building on Athedra's suggestion; modify the XS750 seat like this:-
                  Unbolt and carefully save the hinges and the latch.
                  Make a new tongue patterned from the XS11 tongue and rob the hold-downs off the XS11 seat.
                  Install nutserts in the XS750 seat base spaced to bolt on the tongue and the hold-downs in the correct locations.
                  If you did it right the XS750 seat should now attach properly.
                  As the nutserts install almost flush you can leave them in place if the XS750 seat needs to go back on an XS750 at some future date.
                  • jwhughes3
                    • 2798
                    • Home of the Alamo
                    that sounds doable...
                    thanks Fred I may try it.
                    John
                    • jwhughes3
                      • 2798
                      • Home of the Alamo
                      OK - I bought it - now you will find out...
                      if I can make it work.
                      Pics if it does - tears if it doesn't
                      At least SWMBO likes the idea of a comfy seat!
                      John in San Antonio
                      • Athedra
                        • Oct 2009
                        • 221
                        Nice seat. let us know if you get it working.
                        Thanks for not welding or grinding your original frame. Will thank me for it someday.
                        1196 Big Bore
                        4-1 Cowley exhaust
                        750FD Conversion
                        BMX footpegs
