'79 Parts Manual
  • Athedra
    • Oct 2009
    • 221
    • Benoni, South Africa
    '79 Parts Manual
    Can anyone refer me to a parts manual in pdf for a 79 xs1100 standard.
    I downloaded a couple for the 81 XS1100H, but need for the 79 standard.
    '79 XS1100 (2H9) named Bones
    1196 Big Bore
    4-1 Cowley exhaust
    750FD Conversion
    Echlin 54mm Racing Cones (Americanese = pods)
    Black Ebony Bottled glazed Tank (To be redone now)
    BMX footpegs
    Tank internally lined (Professionally this time)
    GSX400 Throttle bodies (Under serious investigation)
    Anti Sticky float bowl system
  • b.walker5
    • Feb 2009
    • 1745
    • Invercargill, New Zealand
    I havent got a manual for a standard, only a special, but if you check this site you'll find all the part numbers you need.
    • Athedra
      • Oct 2009
      • 221
      Thanks, question tho.
      I have the '79 XS1100 standard European. Would that make it a XS1100E (for european) or XS1100S (for Standard)
      I dont see just XS1100 in the drop down list there.
      1196 Big Bore
      4-1 Cowley exhaust
      750FD Conversion
      BMX footpegs
      • GARTHXS
        • 1631
        • Seattle
        xs1100e
        is a 78 the 79 is an xs1100f if you could post a pic of your bike we could tell ,
        I think Euro sports have letters like rf rh rg, but that is just speculation,
        91 kwaka kz1000p
        Stock
        ( Insert clever quote here )
        • Athedra
          • Oct 2009
          • 221
          So far this is the closest I could find to mine.
          1196 Big Bore
          4-1 Cowley exhaust
          750FD Conversion
          BMX footpegs
          • b.walker5
            • Feb 2009
            • 1745
            Use the first 3 letters of your engine number (probably 2H7) in the model id box on the parts site, with 'any' in the model box, then click 'go find' and you should see the model series in the left hand column.
            • Athedra
              • Oct 2009
              • 221
              K, got all those done, says it's a XS11002H9
              Least I got that part done now. Thanks. And finally see that the bike is not New Yamaha Black, but Black gold.
              This clears up several problems I ran into
              1196 Big Bore
              4-1 Cowley exhaust
              750FD Conversion
              BMX footpegs
