XS1100R--Sports model
  • ericaa
    • Aug 2009
    • 2
    I was wondering if anyone can steer me in the right direction?I have a set of perforated diaphragms, and am after replacements!
    Im told they are not avail new anymore--so what do I do --without spending heaps on new carbs?
    The bike is an Australian 3/82 XS1100R vin 5n5-000919
    Diaphragm part no 5K7-14940-00
    I have purchased a set of diaphragm slides from the USA that I cant use(which were for the wrong model--.035" shorter slides-Capitol Carbs).
    Any suggestions would be really appreciated!!!!!!!!!
    Thanx Guys---
    Cheers-Eric from Aussie
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    Thanx Guys---
    I believe that sirius con online has just the diaphrams which can be replaced while using your original slides. My XS400 uses the same carbs and slides so I ordered new diaphrams and replaced them about a year ago, they are still working just like new.
    • Athedra
      • Oct 2009
      • 221
      • Benoni, South Africa
      If you cant find the right ones, dab it with a bit of silicone on both sides of the tear or hole. Just a thin layer on both sides. This will keep your bike moving until you can get the right stuff.
      We have a place called "Diaphragm Man". You drop off your sample and they will make you new ones. See if you guys maybe have someone like that in Australia. In short all they do is silicone moldings, and that is all you basically need.
      Unfortunately a lot of the parts we need is made out of unobtainium, so most of us has started using what we can get hold of and changing to suite the current market. I am now currently looking into the possibility of making throttle bodies for my XS with a fuel and timing management system. So far things look promising, and it will be a nice upgrade to new technology along with some added VROOOOOMMMMMMMMmmmm to the bike. This upgrade will also bypass all the small parts made out of unobtainium. Fortunate for me a purchased a good set of Crabs about two weeks ago, and have the old set to play and fidget with. Currently the R1 seems to be the best injectors and fuel/timing unit that can be modified onto my old carbs. Will eventually be at a point where I will post the project, but is currently in it's very early stages so dont have enough info to give more.
      '79 XS1100 (2H9) named Bones
      1196 Big Bore
      4-1 Cowley exhaust
      750FD Conversion
      Echlin 54mm Racing Cones (Americanese = pods)
      Black Ebony Bottled glazed Tank (To be redone now)
      BMX footpegs
      Tank internally lined (Professionally this time)
      GSX400 Throttle bodies (Under serious investigation)
      Anti Sticky float bowl system
        The diaphragms are available, as are all parts for the carbs. They are a bit expensive, but if you only have to replace it once, and wait another 30 years to do it again, it's not that bad. All the other parts are readily available from several sources.
        Athedra - The EFI project has been done, and a few members here are running it. Here's a thread on one member's Megasquirt EFI project.
        • TomRodgers
          • Jun 2008
          • 492
          • La Porte Indiana
          Athedra...i hope this was a typo
          I had same issue on a Scorpion snowmobile. i used a thin layer of silicone on them and worked fine for, oh, 10 years now....
          '81H (my first XS ) "Grey Ghost"
          4:1 Jardine w/ headerwrap
          Windjammer(wiring issues)
          New paint/brakes to come!!
          '80G FrankenBike (parts bike)
          '80G to fix "BlackSunshine"
          Stock Pilots/125 mains
          Pod filters; 4:1 Kerker??
          SS Brake lines w/ new M/C's
          LED Brake Lite
          Needs paint....
          • Athedra
            • Oct 2009
            • 221
            Hahahaha, Crabs / Carbs ummmm definite typo. (Hate this auto typing correct thing)
            1196 Big Bore
            4-1 Cowley exhaust
            750FD Conversion
            BMX footpegs
            • Guy_b_g
              • May 2007
              • 790
              • Beverly Hills, Florida
              Imagining trying to synchronize four crabs..
              Guy
              '78E
              • Athedra
                • Oct 2009
                • 221
                One on each finger?
                1196 Big Bore
                4-1 Cowley exhaust
                750FD Conversion
                BMX footpegs
                • Paul Kelley
                  • Apr 2009
                  • 27
                  • Apple Valley Ca.
                  Carb parts
                  Hello,
                  I found sudco. com has A lot of replacement parts and also new carbs.
                  That is where I got my neww set of CR racing carbs (Kiehen),also stock Mukuni stuff. Paul Kelley
                    IT must take Paula Abdul to choreograph them like that.
                    • Guy_b_g
                      • May 2007
                      • 790
                      I'm sure it's easier with a good set...
                      Just be careful...old crabs can be grumpy..
                      Guy
                      '78E
                      • Athedra
                        • Oct 2009
                        • 221
                        Yeah just imagine sticking R1 injectors in them with the timing/ignition unit.
                        1196 Big Bore
                        4-1 Cowley exhaust
                        750FD Conversion
                        BMX footpegs
