Camshaft dot position relative to the T
  • digitalsam
    • Aug 2008
    • 208
    • Carlsbad, NM
    Rather than filling the tank and testing the bike, I thought I would take a look at the position of the cams before I put it all back together. When cylinders 1 and 4 are at dead top the dot on the cams was about an eighth of an inch off center. Since I had already ruined the gasket, I thought I would fix it. And now it is fixed. Tada!
    My question is... would that 1/8 of an inch have caused problems or is it too little to really care about? It is a moot point, now that it is fixed, but it would be good to know.
    Also, can I use Permatex high temp to make a new gasket, or should I wait for a new gasket to arrive. Funds are tight at the moment, which is the main reason I ask.
    Sam Christensen
    The Chronicles of my Rebuild http://xs1100rebuild.blogspot.com
    If you are leading and no one is following, maybe your just taking a walk.
    Currently bikeless. Sold my 1980 XS1100 Special
    Sam,
    As to the gasket, yeah you can use the permatex type gasket for the valve cover.
    As to the 1/8", I am curious how you fixed it to help determine the answer to your question.
    • digitalsam
      • Aug 2008
      • 208
      • Carlsbad, NM
      I pulled the cover, manually rotated the timing plate to the "T" making sure the 1 & 4 Cylinders were dead top first. I stuffed the holes with rags to avoid any nut dropage. Then I removed the sprockets from the cams and carefully and evenly loosed the cam caps. I rotated the camshafts so that the dot lined up. I tightened the cam caps, slowly and evenly and torqued them down. Then having stuffed the holes with rags again, I bolted the sprockets to the cams, checked the dot again and rotated the engine a few times in the correct direction to make sure that the dots lined up after a few rotations. When they did, I covered everything to keep out the dust and came in for the evening.
      Sam Christensen
      • digitalsam
        • Aug 2008
        • 208
        • Carlsbad, NM
        For the gasket, what would work better, Permatex Ultra Black High-temp or the Yamabond #4 that I used to seal the cases?
        Sam Christensen
        • kirmit77
          • Mar 2009
          • 464
          • Kingwood, TX
          I like to use permetex Right Stuff gasket ... works REALLY good better than high temp
          Austin Ingalls
          MIDNIGHT FURY
          1979 XS1100 Special [Full Restore Project]
          XJ maxim rear air shocks
          KERKER 4-into-1 exhaust
          Pod Filters
          Money pit.......
          BLACKED OUT
            Use the yamabond, but oil the head side. That way the head will be clean, and the valve cover is OFF for the cleaning!
            • mxmikie
              • Aug 2008
              • 482
              • Bouse az
              hylomar works best
              • dbeardslee
                • 4385
                • Maineville, OH
                Digital - Have the sprockets been off the cams before? I just went through something similar with another members bike - the dots just didn't want to line up. I wound up putting a degree wheel on it, and made things more complicated than they needed to be. If the sprockets haven't been off the cams all you should have to do is put the timing mark on the 'T' and get the dots as close as you can to the pointers. As the chain stretches the dots are going to move around a little anyway.
                • digitalsam
                  • Aug 2008
                  • 208
                  • Carlsbad, NM
                  Yup, when I tore the engine down completely.
                  Mine seemed to set right in, I didn't know if it would be an issue with the valves opening prematurely or postmaturely (doubt that is a word). Anyway, I got them to line up perfectly. Not sure what I did differently this time.
                  Wont that cause the pre/post valve opening issue?
                  Sam Christensen
                  • dbeardslee
                    • 4385
                    • Maineville, OH
                    I'm sure they allowed for it in the design. As the chain stretches the dots move slightly 'away' from each other (as you view it from on-top). There's no way to keep it from doing that other than not running it. I was curious why you moved the sprockets, but if they were off the cams it makes sense that they may have needed tweaked. The arrows on the bearing caps are not the most precise measuring device there is, but it's still nice to have everything pointing where it should. Is the cam chain new?
