G into a Special
  • Filter
  • G into a Special
    I have a 80G but just picked up a 82 special parts bike. I am going to switch the forks but I'am wondering what other parts I can swap besides the seat and tank and side covers? How different are the frames? Thanks Den
  • #2
    I have only owned Specials so far, so I am not 100% certain. I believe though that the frames are different for side cover mounts, and exhaust support positions.
    Also, if you switch out the forks, you may want to also switch out the triple trees. Otherwise you change the steering geometry.
    • #3
      If you have an 82 "special" I am guessing you have a 82 XJ1100 maxim. Frames are different. Engines are the same, only different. Electronics are different for the most part as well.
      The experts will have to weigh in on the specifics. I haven't torn open my XJ yet.
      Everything on hold...
      • #4
        That's almost precisely what I was thinking.
        Ich habe dich nicht gefragt.
        • #5
          Hi Den,
          XS Standard & XS Special forks will swap. To swap with no change in fork trail the complete fork has to move, 'trees and all.
          But presumably your '82 has to be an XJ? Dunno if XJ forks are different. Try this, carefully measure the distance between the XS front & rear axles then swap the XJ's forks in and measure again.
          If the number is the same you are golden. If it's less, the front wheel is further back and she'll steer heavy; if it's more, the front wheel is further ahead and she'll steer light. +/- a 1/2" shouldn't feel all that different; more may be noticable.
          For all the other stuff, tanks, sidepanels, seat etc, just try them and see.
