Moving the bike
  • dbeardslee
    • 4385
    • Maineville, OH
    Mastering the slow turn
    Here's a tip on slow u-turns. Rev the motor to 2.5k rpms, and hold it there - the motor will kind of act as a gyro-stabilizer. Sit up real straight and don't lean - steer. Go very slowly and control your speed using the clutch and rear brake only. Find yourself an open parking lot to practice in. Once you've mastered it, you should be able to turn the bike in two parking spaces as some have mentioned.
    • Kmccaslan
      • Oct 2009
      • 44
      Tried the slow U turn...luckily no one was around. I was almost all the way through when the xs11 decided to use its weight against me. It sure is a heavy little thing picking up off that ground.
      Judgments prevent us from seeing the good that lies beyond appearances.
      '79 xs1100 Special (All Blacked Out)
        Oops! It's ok - it happens to everybody. Just try it again, and remember that if it starts to go over, a blip of the throttle will help stand it up again. Of course, it helps if there are no other vehicles nearby when you are practicing.
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          Or if your doing it right with the engine at 2.5k and slipping the clutch, just release the clutch a bit to put power to the rear wheel.
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            Go to a vacant parking lot when no one is around (DMV on a Sat or Sun?) and start doing figure-8's.
            Shrink the size of them. No reason to limit yourself to only being able to turn one direction easily.
            You can turn in a surprizingly tight circle with these bikes after awhile.
            FWIW, it's tough to roll these bikes on grass period.
            Pat Kelly
            <p-lkelly@sbcglobal.net>
            1978 XS1100E (The Force)
            1980 XS1100LG (The Dark Side)
            1999 Suburban (The Ship)
            1994 Dodge Spirit (Son #1)
            1968 F100 (Valentine)
            • Dragon Tamer
              XStremely XSive(Deceased)
              • Sep 2006
              • 426
              • Half way between Chili and Winter Wisconsin.
              Yes, you will find it easier to maneuver one of these at the above 2.5 to 3k rpm range if you put a steady pressure on the rear brake pedal and control the speed with the clutch. It sounds funny at first to hear the engine revving a little but with the resistance from the rear brake she tends to stand up very nicely. If this causes it to get twitchy then you have to check the front brakes to see that they are not dragging.
              Taught my sons to ride this way and either of them can do a U turn in about one and a half parking spots and one of them is now riding a K Vulcan Nomad, If he can do it with that truck anyone can.
              The Old Tamer
              _________________________
              1979 XS1100SF (The Fire Dragon)
              1982 650 Maxim (The Little Dragon)
              another '82 650 Maxim (Parts Dragon)
              1981 XS1100SH (The Black Dragon)
              If there are more than three bolts holding it on there, it is most likely a very important part!
              • TomRodgers
                • Jun 2008
                • 492
                • La Porte Indiana
                Go to northern tool dot com. under trailers and moving they have one for 139 bucks.....
                '81H (my first XS ) "Grey Ghost"
                4:1 Jardine w/ headerwrap
                Windjammer(wiring issues)
                New paint/brakes to come!!
                '80G FrankenBike (parts bike)
                '80G to fix "BlackSunshine"
                Stock Pilots/125 mains
                Pod filters; 4:1 Kerker??
                SS Brake lines w/ new M/C's
                LED Brake Lite
                Needs paint....
                • randy
                  • Dec 2003
                  • 4521
                  If I stare at that avatar long enough will the straps break?
                    • 8962
                    I don't know, but you could try these...
                    • tarzan
                      • 1700
                      • Chandler,Az.
                      I'm getting dizzy
                      80 SG XS1100
                      14 Victory Cross Country
                      • XS1100 Newbie
                        • Jun 2009
                        • 1106
                        • Battle Ground, Washington
                        I don't even feel bad if i have to push my bike back out of a spot. Pee on their old bald heads if they laugh. I am to short to reach the ground with both feet at once. I practice all the time in slow tight corners. Getting better all the time.
                        P.S. Those bouncing things make me dizzy too.
                        1980 XS1100LG Midnight
                        1991 Honda CBR1000F Hurricane
                        A cold beer and another one!
                        • dbeardslee
                          • 4385
                          • Maineville, OH
                          My mom told me if I looked at stuff like that I'd turn to stone. I quickly quit looking cause I felt myself starting to stiffen up .
                          • Guy_b_g
                            • May 2007
                            • 790
                            • Beverly Hills, Florida
                            Kat where are ya? You know you want to comment....lol
                            Guy
                            '78E
