bike quit
  • flyvee1
    • Jul 2003
    • 4
    bike quit
    ok guys ,,i thought my woes were over ,so the wife and i jumped on the bike rode about 3 miles down the road ,,and all the sudden the bike started running irrattic,,the it started bucking badly and then it shut down!it left me with the same symptoms as before,,,turn the ignition on ,everything works,turn signals,brakelights,horn,etc,hit the starter button?,nothing,jump the selinoid,,,starts right up,,take jumper off the selinoid ?..it dies....electrical is no fun ,,i took the tank off ,looked for loose connections ,to no avail,all the fuses are ok,. im lost lol ,pleeze
    help ,thanks alot ,tom
    1980 xs 1100 special
    1980 xs650 special II
    1980 xt500
    1976 xt500
    1985 fl350r odyssey
    1979 fl250r odyssey
    1976 cb350 nice!
  • Stava
    • Jan 2003
    • 41
    • Victoria, Australia.
    G'day Tom,
    I have just had the exact same problem after swapping out my battery for a new one. (not that it had anything to do with it)
    I found that the red and white wire from the kill switch had an huge amount of impedance and was not completing the ignition circuit.
    I found a wire had been stretched and had an internal break in the loom.
    I simply disconnected the offending wire and rerouted a new one to the solenoid to fix the problem.
    Later I will unravel the loom and fix it properly.
    Preferably when the riding weather is lousy!
    Hope this helps,
    Ride Safe Ride Free.
    Stava.
    • Stava
      • Jan 2003
      • 41
      G'day again,
      BTW it was a tip /advise from Gary Granger that gave me the clue as to where to fault find the problem.
      His reply is in this section of the forum, just follow Stava thread.
      Follow it down and you will find the source of the gremlin!
