General information
Model: Yamaha XS 850
Year: 1980
Category: Touring
Rating: 77.4 out of 100. Show full rating and compare with other bikes
Safety: See our safety campaign with the high safety rated bikes in this category.
Engine and transmission
Displacement: 826.00 ccm (50.40 cubic inches)
Engine type: In-line three
Stroke: 4
Power: 79.00 HP (57.7 kW)) @ 8500 RPM
Compression: 9.2:1
Bore x stroke: 71.5 x 68.6 mm (2.8 x 2.7 inches)
Valves per cylinder: 2
Fuel control: DOHC
Cooling system: Air
Gearbox: 5-speed
Transmission type
final drive: Shaft drive (cardan)
Physical measures
Weight incl. oil, gas, etc: 258.0 kg (568.8 pounds)
Chassis and dimensions
Front tyre dimensions: 3.25-19
Rear tyre dimensions: 4.00-18
Front brakes: Dual disc
Rear brakes: Single disc
Speed and acceleration
Top speed: 196.0 km/h (121.8 mph)
Other specifications
Fuel capacity: 24.00 litres (6.34 gallons)
General information
Model: Yamaha XS 1100
Year: 1980
Category: Classic
Rating: 79.4 out of 100. Show full rating and compare with other bikes
Displacement: 1101.00 ccm (67.18 cubic inches)
Engine type: In-line four
Stroke: 4
Power: 95.00 HP (69.3 kW)) @ 8500 RPM
Compression: 9.2:1
Fuel control: DOHC
Cooling system: Air
Gearbox: 5-speed
Transmission type
Physical measures
Weight incl. oil, gas, etc: 286.0 kg (630.5 pounds)
Front tyre dimensions: 3.50-19
Rear tyre dimensions: 4.50-17
Top speed: 215.0 km/h (133.6 mph)
Year: 1980
Category: Touring
Stroke: 4
Compression: 9.2:1
Fuel control: DOHC
Cooling system: Air
Gearbox: 5-speed
Transmission type
Physical measures
General information
Year: 1980
Category: Classic
Stroke: 4
Compression: 9.2:1
Fuel control: DOHC
Cooling system: Air
Gearbox: 5-speed
Transmission type
Physical measures
