Choke wont stay in the out position
  • digitalsam
    • Aug 2008
    • 208
    • Carlsbad, NM
    I took the carbs completely apart and cleaned them. Reassembled them and put them on the bike. Went to start it up and noticed that the choke bar no longer stays in the out position.
    Any thoughts on why this is?
    I don't think I left anything off. It wont run without the choke out and holding it out by hand is probably not going to work over the long term. Still need to sync the carbs, but will have to fix this issue first.
    Sam Christensen
    The Chronicles of my Rebuild http://xs1100rebuild.blogspot.com
    If you are leading and no one is following, maybe your just taking a walk.
    Currently bikeless. Sold my 1980 XS1100 Special
  • dbeardslee
    • Nov 2007
    • 4385
    • Maineville, OH
    Sounds like you lost the springs and tiny ball bearings that hit the notches to hold it out. The ball bearings are only about 1/8" in diameter, and they will really fly if you're not careful when pulling the bar out.
    • digitalsam
      • Aug 2008
      • 208
      • Carlsbad, NM
      I have the bearings in, But no springs... I found one one the work bench, should there be two?
      Sam Christensen
      • dbeardslee
        • Nov 2007
        • 4385
        • Maineville, OH
        Yup. One should hold it though. You might be able to find a suitable substitute at a hardware store, or they can be ordered from Bikebandit. BB wants about $5 for the spring, so the HW store might be a more economical solution.
        • petejw
          • 2269
          • sydney australia
          Ive been running mine without any balls/spring
          in the choke, just means you need to hold it open
          for a short time.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
            I just had the choke bar and assembly removed on the set for my project bike. When I looked at the bar, I noticed that the only place it has notches for the ball to sit in and hold the choke in position is at no 1 carb. So it seems the one at number foru carb is just there for a feel good or to store an extra in case you loose the one at no 1 position.
            Yep, it won't do didly for you if you do not have the spring, it is a small one to.
            • HobbyMan
              MeatHead Idiot "GURU"
              • Jul 2006
              • 1801
              • Colleyville, TX
              Also, make sure the rod is lined up properly. It must be oriented properly to catch the balls
              Acta Non Verba
              • TomRodgers
                • Jun 2008
                • 492
                • La Porte Indiana
                he said "catch the balls" hehehe
                4:1 Jardine w/ headerwrap
                Windjammer(wiring issues)
                New paint/brakes to come!!
                '80G FrankenBike (parts bike)
                '80G to fix "BlackSunshine"
                Stock Pilots/125 mains
                Pod filters; 4:1 Kerker??
                SS Brake lines w/ new M/C's
                LED Brake Lite
                Needs paint....
                • dbeardslee
                  • Nov 2007
                  • 4385
                  • Maineville, OH
                  O.K., Beavis....lol
                    Sorry, could not resist it...Link
                    Now THAT is "catchin the ball"
                    Ok...back to the regularly scheduled thread now.
                    • CatatonicBug
                      • 6117
                      • Clinton, UT
                      I recently took mine apart and "lost" one of the balls. The other one was jammed down in the hole. I fished that one out, but really wanted to make sure they were all there. I figured out that I had a few extra balls in my RC car parts bin, left over from a differential gear. They work great! The funny part is that right after I found a replacement, I found the original ball too. The springs, I don't know about, since they are rather tiny. I have never seen such a tiny spring in any store...
