tkat vs telefix fork brace
    What is the difference in a fork that is braced - what are we eliminating?
    I have never ridden a bike that was "braced" so I am unsure if it is something I would need - if the ride feels OK without it - what would prompt me to add it?
    Thanks
    John in San Antonio
    The brace reduces the fork flex in these undersized 37MM forks. Put your bike on the center stand, stand over the front wheel facing the handlebars. With the wheel in between your knees, twist the handlebars back and fourth. This is your fork flex, a lot huh? With the brace installed, the flex is virtually eliminated. You'll notice the improvement in handling especially in the twisties.
    • dbeardslee
      • 4385
      • Maineville, OH
      Reprinted from XS11 Info -
      The XS11's front fork lacks torsional stiffness--something it shares with most bikes that do not clamp the front axle on both sides. The most important factor in front fork stiffness is how well the front axle is clamped. Of course, the XS11's axle is clamped only on one side. When new, friction between the fork leg and the axle will hold it pretty well. After a few thousand miles, however, the axle polishes the hole it fits into and the fork assembly will begin to move around. This is one of the reasons wobble problems tend to show up after several thousand miles. The answer is a fork brace.
      • jwhughes3
        • 2798
        • Home of the Alamo
        thanks!
        answers my questions -i guess i do not push it hard enough to feel the flex.
        i will likely go ahead and put a brace on and see the difference though.
        john in san antonio
        '81 XS1100H - "Enterprise"
          jwhughs3.......you'll notice the difference right away.......as in turning your first corner at 5-10mph, I almost turned it "under" itself and fell over, response was instant to direction change!
          • DeanR
            • Jan 2005
            • 1499
            • Finger Lakes NY
            Very little clearance between the TKat and the fender on my Special. It just clears and it works wonders.
            80 SG
            81 SH in parts
            99 ST1100
            91 ST1100
            • rover
              • Jan 2004
              • 765
              • central WI (715)
              Fork Brace
              I made my fork brace out of 10 ga stainless. It fits under the fender and attaches to the fender mounts on the inside of the fork. Can't see it from the outside, just fills the slots in the fender ears. This is very hard to do, even with a high tech bending brake. It must be bent perfectly square and even, and the mounting holes drilled in perfect alignment. And the mounting bolts should be about 5mm longer to make up for the added thickness, so they won't pull out of the mounting holes. If my time were worth $10.00 per hour, this would be an expensive way to go.
              79 F (Blueballs)
              79 SF (Redbutt)
              81 LH (organ donor)
              76 CB 750 (gone to MC heaven)
              rover has spoken
              • Eveready1100
                • 539
                Just curious. Aren't the sliders a different outside diameter as the inside diameter where the fork seals fit are different?
                • cywelchjr
                  XS-XJ Super Guru(Deceased)
                  • 4450
                  • Sacramento, CA
                  My understanding is that the sliders are the same diameter, as are the inner tubes, but where they go is machined differently, and the special has some sort of assembly on the end of the inner fork tube as a bushing so they can't be swapped between standard and special. But the fenders mount differently and that means that the special braces need the part that goes over the fender higher than a standard does. Of course I could be 99.9% wrong too, so take the word of anybody who comes in here that has experience with BOTH standards and specials, I'm a standard guy, cause I can't find a special to buy, so I can put a sidecar on it, and turn it half way into a standard with a standard tank and be like Fred.
                  • Eveready1100
                    • 539
                    Hi Cy. Last year, I had dramas with my fork seals which were documented in quite a few posts on here, and through frustration, fitted my Special tubes with Standard sliders, which do fit, and work well. The only real downside is that you end up with instant 4 inch overs, which is good if you're after the chopper look, but is a pain if you just want a bike you can ride, and park safely without it wanting to fall over off the sidestand.
                    Guess I better dig out my verniers and actually measure them.
                    I'll let you know the result
                    • b.walker5
                      • Feb 2009
                      • 1745
                      • Invercargill, New Zealand
                      Originally posted by Elevener
                      Here was my reasoning. Telefix is powdercoated, nice if you have a midnight maybe. Telefix cost more.
                      Tkat is aluminium, looks to be at least mildly polished. Tkat is cheaper, many here use it. I may be wrong here but I dont think so.. Buying from Tkat supports an individual who is presumably also an XS enthusiast.
                      Tkat won with me, thats why I sent him a check this week.
                      I painted my Tkat brace wth Rustoleum satin black. Three coats of this looks just like powder coat and it's extremely tough.
                      Took some getting used to riding with a rigid front end but i wouldnt go back for quids now.
                      • lancelot455
                        • Sep 2010
                        • 174
                        • Regina,Saskatchewan,Canada
                        Will the Tkat brace fit on a XJ1100?
                        82 XJ1100
                        Canada
                        2006 V-Star 1100 custom
                        • dbeardslee
                          • 4385
                          • Maineville, OH
                          Dunno. You could probably check with TKAT though - there's and e-mail link at the bottom of this page.
                          • Elevener
                            • 608
                            • small town in TEXAS
                            He had a post on the yahoo groups looking for the thickness so he is probably fixin to make one.
                            Trapped in time. Surrounded by evil. Low on gas.
                            1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
                            • Crusty Snippets
                              • Sep 2010
                              • 428
                              • Gabriola BC
                              Brace
                              john in san antonio
                              My front wheel wobbles when I am going slow, no pushing required.
                              Have ordered a brace from Tkat, looking forward to having it installed.
                              Crusty
                              • justme1100
                                • Jul 2008
                                • 243
                                • Eagle, WI
                                My understanding is that the XJ has a brace built into (under) the front fender. If that isn't a brace under there it is an extremely beefy fender mount. With no experience with a Special or Standard I can't say if it is different.
                                Just ME and my 82 XJ 1100. Mac 4>1-2 1/2" open baffle shotgun, no octy, K&N pod filters, LED tail/brake light & directionals, 750 FD mod, Ear Cannon air horn, modified bars and dash. "Motorcyclists are all bound together by a brotherhood tie through their love of the sport, and what difference does it make what machine he rides as long as he belongs to the clan." Walter Davidson, Dec. 1920 edition of Harley-Davidson Enthusiast Magazine http://s851.photobucket.com/albums/ab78/justme1100/
