Some advice please
  • Some advice please
    driving down the road bike starts to lose power then backfire through the exhaust sometimes picks back up and goes other times just dies and then takes about 15 min. or so before it will fire again.
    Utah
    1981 XS1100SH
    What does it sound like when it finally fires again? Is this a recurring problem or did it just happen once? Does the bike run now? How long will it run before this happens? Does it always go the same distance (more or less) before it quits?
    Details, please.
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
      it has happened twice and it is a loud bang out of the exhaust once at a short distance and the other time after about 6 miles when it starts again sounds fine put a after market air filter in it. it is cold where i live right now.
      Utah
      1981 XS1100SH
        it happened the first time after the airfilter was installed but not sure if that wis the problem or just coincidence
        Utah
        1981 XS1100SH
          I think lean usually means backfire though the carbs. Do you have inline fuel filters? Could be slowing the fuel to the carbs, slowly starving the engine.
          Might be way off on this.
          Kinked fuel lines?
          Now for the experts---
          Everything on hold...
            no inline filters looked at lines seem fine no kinks and all four pipes are hot
            Utah
            1981 XS1100SH
              Do a search here for 'pickup coil fix"
                How about a partially clogged fuel cap vent?
                  What is the year and model of your bike?
                  1969 Yamaha DT1B
                    it is a 1981 xs1100sh which is the special where is the best place to get pick up coil if that is the problem thanks
                    Utah
                    1981 XS1100SH
                      Won't be the pickup coils but the wires at the coils. It's an easy fix. check out the tech help links on the main forum page.
                      Here's the link.
                      http://www.xs11.com/forum/showthread.php?t=543
                      Hope that helps
                      Paul
                      1983 XJ1100 Maxim
                      1979 XS1100 Standard
                      1980 XS1100 Special
                      I'm not a motorcycle mechanic but I play one on the internet.
                        thanks for the help will check it out and go from there
                        Utah
                        1981 XS1100SH
                        • #13
                          Double check the fuel tank vent.
                          Intermittant fuel supply can do this also.
                          I was gonna say pickup-ups too, but wrong bike.
                          John
                          Now: '78 XS1100E 750 FD Mod (Big Dog)
                          '81 CB900C ( 10 Speed)
                          '78 CB750F ( The F)
                          '76 CB400F ( The Elf)
                          New '82 Honda MB5 Ring Ding
                          Then: '76 CB550K
                          '78 CB750F
                          '84 VF1100S
                          And still Looking!
                          • #14
                            thanks for the help going to check it out this weekend
                            Utah
                            1981 XS1100SH
                            • #15
                              Could the aftermarket air filter plugging the holes in the carb cause this?
                              JAT
                              Dan
                              Current Rides: '82 XJ w/Jardine 4-1's, GIVI flyscreen, '97 Triumph Trophy 1200
                              Former Rides: '71 CB350, '78 400 Hawk, '75 CB550/4;
                              while in Japan: '86 KLR250, '86 VT250Z, '86 XL600R, '82 CB450(Hawk II), '96 750 Nighthawk, '96 BMW F650
