mikes xs green coils
  • furious4
    • Jun 2009
    • 80
    • St. Cloud Florida
    I'm in the process of installing my new green monsters I read that the wires going to the coils can be hooked up both ways is this right? and the correct way to hook up the plug wires I know the coils run certain cylinders but how do you know which one should plug in at the coil since theres two options. I'm stupid and need help
    1980 Midnight Special Its so fast it blew the gold right off
    mikes xs green monster coils, ss brake lines,
    Previous Bike
    1973 XS650
    • 8800
    That is correct, the polarity running to the coils can be hooked up either way. The coil which you have hooked the orange lead to will go to cyls 1+4, the coil with the grey lead will go to cyls 2+3. Both spark plug wires on each coil fire at the same time (wasted spark system), so as long as they go to 1+4 and 2+3, you're good.
    • furious4
      • Jun 2009
      • 80
      • St. Cloud Florida
      Thanks so much. back to work
      Previous Bike
      1973 XS650
      • furious4
        • Jun 2009
        • 80
        • St. Cloud Florida
        The monsters are alive
        I got the mikes xs green coils installed today Thanks again Bikerphil. It runs great off idle. when idling #3 cylinder cuts in and out soon as throttle is given runs on all four very smoothly. guess I'm pullin the carbs back off. I'm thinking it must be a pilot circuit issue. at least I have the coils installed so I wont shock myself anymore
        Previous Bike
        1973 XS650
        • tw1980
          • Apr 2009
          • 662
          • Bend OR
          You probably already know this,but since it's not in this thread I'll bring it up.You're supposed to remove the resister when you Install the green coils.Sorry if everybody already knew that.
          Terry
          1980 special (Phyllis)
          1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod
