Can someone tell me if the jardine 4into1 exits in front or behind the rear axle? can you keep the centerstand and can you change the oil filter?I have a 1979 xs1100 special.Thanks!
jardine 4into1
It exits an inch or two behind the axle so the can has to be removed to get the axle out. The oil filter is not in the way, and you can leave the center stand on. At least thats true for my 79 std, shouldnt be different for the special. Others will let you know if it is. GL!'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~ -
Something interesting I learned a few weeks ago about the XS11 is the factory tool kit had a cable that attached from the swing arm to the frame near the shock absorber mount that held the spring compressed so the rear axle could be removed without taking the mufflers loose.
Smart guys those Yamaha engineers.Ich habe dich nicht gefragt.Comment
My pipes block the axle, I took the shocks off and used a tie down strap to raise swingarm. Shocks were easier to remove than pipes.Trapped in time. Surrounded by evil. Low on gas.
1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifierComment
With my jardine I've found I can remove the rear exhaust mounting bolt and push the silencer out of the way to get access to the rear axle without any special tools. I did have to fabricate a little metal strap to accomodate the rear mounting bolt, as the bracket that's welded to the silencer just won't reach. My $.02I think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
