pita carbs
  • GARTHXS
    • 1631
    • Seattle
    pita carbs
    So my 79f wasn't running thatgreat so I pulled the carbs and checked em out found a broken idle mix screw tip and got it out but I am having a heck of a hard time getting this bike to run right , intermittent sticking float valves(new) and reset float hight 25.5 and still running rich
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
  • soccer4m
    • 694
    try this
    Hey Garth,,,,maybe some new plugs, a dose of seafoam, clean airfilter, pray to the carb Gods,,,,,,,or call Scott........ride next weekend if you get the time,,,Mike in V.C.
    mike
    1982 xj1100 maxim
    1981 venture bagger
    1999 Kawi Nomad 1500 greenie
    1959 wife
    • tarzan
      • 1700
      • Chandler,Az.
      ould the sticking float be a float catching the side of the bowl from being cocked or bent?Or could the gasket be catching on it?
      80 SG XS1100
      14 Victory Cross Country
      • mro
        • 4276
        • Hayward, California
        All cylinders rich or just one or two?
        While most of the time a rich condition means fuel/air, can also be electrical. Like weak spark from old plugs, corrosion in connections (plug caps or coil feed wires etc.).
        As for sticking "float valves (new)", I don't know. Did you replace the seats too?
        Only ones that I've ever had a problem with had junk sticking em open or were worn.
        mro
        • 81xsproject
          • 3185
          • Fortuna, CA
          Also check to make sure it is not the floats sticking against the sides of the bowls. And of course do the PUCW (pick up coil wire[deserves its own acronym ]) repair if you haven't already.
          '81 XS1100 SH
          Sep. 12th 2015
          RIP
          • foreda
            • 949
            • Southwest Louisiana
            PITA Carbs
            How much Ethanol in the gas in your part of the country? You may have to raise the floats from their normal standard settings.
            78 XS1100E Standard
            Coca Cola Red
            Hooker Headers
            1979 XS1100 Special
            1980 XS Standard
            2006 Roadstar Warrior
            • GARTHXS
              • 1631
              • Seattle
              the rundown
              I didnt have time to list all I've done , on these carbs first of all this set of carbs has a broken float post that has been repaired. the fix is a good one but the new post is not as long as the others , so the stop tang sometimes hangs on the edge, and I have done the pickup coil fix , and cleaned and reset float height to 25.5 . this bike has no engine mods except a K&N airfilter . also brand new iridium plugs . i have had this rack off the bike like 4 times , and it ran almost perfect before I took them off . I will try again today , I am going to reset float height to 26.4 and hope that helps rich condition
              91 kwaka kz1000p
              Stock
              • GARTHXS
                • 1631
                • Seattle
                this may be part of the problem , the CA. gas is only 90% gas the other 10 percent is bull****e not unlike myself
                91 kwaka kz1000p
                Stock
                • foreda
                  • 949
                  Which Carb is broken?
                  Which carb is broken. I have a #1,#3 and #4 in my stock of parts.
                  78 XS1100E Standard
                  Coca Cola Red
                  Hooker Headers
                  1979 XS1100 Special
                  1980 XS Standard
                  • foreda
                    • 949
                    Iridium plugs? Did you change the resistor caps?
                    78 XS1100E Standard
                    Coca Cola Red
                    Hooker Headers
                    1979 XS1100 Special
                    1980 XS Standard
                    • XSokieSPECIAL
                      • Jun 2009
                      • 1631
                      • Tulsa, OK
                      I have 79 carbs on my 80 special and after a LOT of dirty words and pulling the rack ? many times, I set the floats at 27mm and it runs good. Still a little rich at low end sometimes though.
                      Holler at Crazcnuk, he's pretty good at that stuff.
                      Helped me a lot.
                      • randy
                        • Dec 2003
                        • 4521
                        At 27mm it should be running pretty damn lean. How'd it get rich? Bigger jets?
                        • XSokieSPECIAL
                          • Jun 2009
                          • 1631
                          • Tulsa, OK
                          No, I'm running the stock 137.5 jets and to tell the truth-I lowered them nearly 2mm. About 27.5 actually.
                          It flooded and ran rich as hell at the recommended setting of 25.7.
                          • randy
                            • Dec 2003
                            • 4521
                            What size pilots?
                            • XSokieSPECIAL
                              • Jun 2009
                              • 1631
                              • Tulsa, OK
                              Oh crap man, I can't remember right at this second. I'm thinking 42. I could be wrong.
                              What ever is stock. The kits I ordered came with stock jets for a 79.
