Position Stop Ball for Carburator Choke Rod
  • Mashermoto
    • Nov 2006
    • 230
    • Yukon, OK
    Just look at'em. Just waiting for that first burst of fuel running through them
    Yep, there is nothing like the smell of freshly rebuilt carbs in the morning
    Now to my question
    You know those pesky little ball bearings that live between the choke rod and that tiny little spring? Well...when I took the rod out, one ball was there and the other wasn't. PO strikes again
    So I'll be spending some time trying to source a replacement Does anybody have any solutions The diameter is 1/8th inch, or about 3mm. I think that's smaller than a BB, but seems like I've seen buck shot about that size
    I'll check back tomorrow to see if anybody has solved this one before. I'd search the posts, but what would I search...small ball choke thingy I'm also assuming it's not something I can order
    My heros have always been flat trackers.
  • TDodge7
    • May 2009
    • 246
    they're on bike bandit for 59 cents
    10: BALL 1/8
    ((PH/R)) [BALL 1/8] 360992-001 $0.59
    • Mashermoto
      • Nov 2006
      • 230
      • Yukon, OK
      Thanks Dodge. I guess I'll have to find something else to buy while I'm there
      • rpgoerlich
        • Dec 2007
        • 643
        • Katy, Tx
        Or try your local Bike Supply shop.
        Richard
        • Incubus
          • 1003
          • Austin TX
          Or a local supplier of ball bearings. Sounds like a common size to me. I bought a bunch of 1/4 ball bearings for the steering head in another of my bikes, whose manufacturer will remain unnamed. Got two dozen of them for a buck. The bearing supplier here in Austin sells 'em.
          Buy local. Keep your neighbors working.
          Patrick
          XS11F (Incubus, daily rider)
          1969 Yamaha DT1B
            I have found this ball size in some low-budget drawer slides I used on a project a while back.
            IIRC, although there is a place for two of these on the choke rod, I thik you only really need one.
            YMMV
            • randy
              • Dec 2003
              • 4521
              McMaster has em $1.98 for a pack of 500. We could start a carb choke rod ball library!
                My choke rod only had one ball (both springs though) until this last weekend. It really only needs one. I just happened to open up my parts box from my RC car racing days, and happened to have a whole pile of 'em, so I dropped one in the empty hole.
                Be sure to grease that rod when you put it back in. That will help it slide more easily.
                  I have a 78E model with only one ball. As the rpms start to increase, it automatically self adjusts to the lower choke position. :-) Like an automatic choke!
                  • petejw
                    • 2269
                    • sydney australia
                    Ive been running mine without any balls,
                    just means having to hold it open by hand for a minute
                    or so.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    1981 xs1100 RH (aus) (5N5)
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                    • Mashermoto
                      • Nov 2006
                      • 230
                      • Yukon, OK
                      Whoooo Hooooo I found some
                      I was so glad that I bought five when I really only needed one The dark one on the bottom is an original.
                      Found them at Ace Hardware for 31 cents each
                      So there you go
