XS650 parts for XS1100
  • thewright1
    • Aug 2009
    • 198
    • Orange County CA
    Hi All,
    I came across this website (I think it was MikesXS) but I found a bunch of parts (mainly gear levers, handlebars, and grips, but I wanted t know if I could use those parts on an XS1100? Is that possible?
    1980 XS1100SG
    In the process of making her look pretty!
    P.S., TomRodgers has the best avatar icon ever!
  • subike
    • 167
    • Christchurch New Zealand
    yes and heaps more, the floationg discs fit the STD 79, the coils are an upgrade on the OME, the switch blocks can be used, just rewire using the 1100 wires and they are the same,some of the wheel bearing kits are the same, plus much more.
    I ordered and used many parts from MikesXS on my 79E std when I rebuilt her.
    Others have as well, as thats where I got the idea from.
    http://i139.photobucket.com/albums/q...e/DSC00009.jpg
    1980 XS1100 Std English Assembled, 378k miles
    In stock untouched contion.
    http://i139.photobucket.com/albums/q...e/seatside.jpg
    1979 XS1100F Std NZ new,
    Mikes XS coils
    Jardine 4-1
    Pod filters
    Harley Davidson Rear Fender
    Bullet signal lights
    Twin 75mm headlights
    Self made single seat
    • Mr.Bill
      • Aug 2009
      • 118
      • Clarksburg Maryland
      "the switch blocks can be used, just rewire using the 1100 wires and they are the same"
      Cool was just going to ask about these. The wiring needs to change because of different connector wiring ?
      Saw part # 24-2058 and 24-2060 left and right switch blocks.
      Looking ahead just in case I needs them
      1979 XS1100SF.
      "You know what makes me sad... YOU DO, Why dont we run over to mamby pamby land and get you some self confidence you jack wagon" Will go down as one of the great quotes LOL
      • subike
        • 167
        yes the blocks are the same, make sure that you order the one with the correct buttons, then it is as easy as taking the wiring out and putting in the 1100 wire. It took me about 10 min per block. But if your switch blocks are not damages, clean them up ,paint them , and order the transfers from MikesXS. they have all them all, cheaper than buying the switch blocks. Mine were stripped in the screw threads,
        Mikes XS coils
        Jardine 4-1
        Pod filters
        • Blank Slate
          • Nov 2013
          • 392
          • Ottawa, Ontario, Canada
          Sorry for the necrobump
          but I have the exact same question as OP. I purchased these grips from mikesxs and the left side fits but the right isn't big enough to fit my 7/8" 1100SF handlebar accessories ... me confused
          Diamond Pattern Chrome type Grips - Black - for 7/8" bars.
          Part #02-2484
          Frame: 79 XS1100S
          Engine: 81 XS1100S
          Carbs: 78-79 BS34
          Gf bike: 78 XS650S
          Carbs: 70-79 BS38
            • 8052
            If those grips don't fit the 11 Special, they won't fit an XS650 either. The bars and the throttle assembly are exactly the same on both bikes.
            I'm pretty sure XS650 foot rest covers are correct for the '78 and '79 XS1100 as well. It got a little tougher because Yamaha has dropped the XS1100SF parts catalog.
            • jayel
              • Apr 2012
              • 152
              • Birmingham, Iowa
              if you look up the part you need on Partzilla it will usually tell you what other models used the same part, as said a lot of stuff interchanges
              where are we going, and why are we in this hand basket?
              Iowa the Beautiful Land 1980 XS1100SG
                • 8052
                That is a problem if you have an XS1100SF. That fiche is NLA.
                • Eveready1100
                  • 539
                  Hi Blank Slate,
                  I had dramas fitting a pair of heated grips to my SF.
                  Solved the fitment problem by filing the ribs off the throttle tube.
                  (That is the issue you're having??)
                  Should be the same for all XS11 models, as Marty has stated previously. They're all the same part (originally)
                  • Blank Slate
                    • Nov 2013
                    • 392
                    Thanks guys, I'll try again before returning them.
                    Frame: 79 XS1100S
                    Engine: 81 XS1100S
                    Carbs: 78-79 BS34
                    Gf bike: 78 XS650S
                    Carbs: 70-79 BS38
                      • 3932
                      Originally posted by Eveready1100
                      Hi Blank Slate,
                      This is something Ras mentioned when fitting the Kuryakyn grips.
                      • tweeleft
                        • May 2009
                        • 110
                        • Bend Oregon
                        therightone you should seach mikes site they have a section for xs1100s
                        Keep the shiny side up
                        1979 XS1100SF
                        Mac 4-1
                        Drilled airbox Uni filter
                        Vmax bars
                        Virago 1" shorter shocks
                        30K miles
                        http://i1228.photobucket.com/albums/...429_135845.jpg
                        1981XS1100SH
                        '80 G Forks and Triple Tree
                        '80 G tank
                        Mac Turnouts
                        Virago 1" shorter rear shocks
                        SH Headlight
                        http://i1228.photobucket.com/albums/...psd6adaae1.jpg
                        61 Wife
                        83 Son
                        86 Son
                        89 Daughter
                          • 8052
                          Problem is, the folks at Mike's don't know anything about an XS1100. They do have a lot of parts that fit, that they can't tell you about.
                          Here's one:
                          Clutch Hub Lock Tab
                          If you try to buy one from Yamaha, you'll find it's NLA.
                            • 3932
                            I received an email from Russ @ Mike's, explaining that he was the new manager, and looked-forward to meeting the needs of the customer. Curious to see what or if anything changes.
