OK, now this is just weird....
  • Incubus
    • 1003
    • Austin TX
    So I was cleaning up Incubus ('79 XS1100F) and putting a windshield on it. Yesterday it ran great. Rode it all over. I got the windshield on and I got it cleaned up a bit and decided to see how well the windshield blocked the wind. Got on and it started right up. But as soon as I put it in gear, it died. The clutch is still disengaging, as I can pull in the lever and push the bike in gear, but it will not start in gear and dies as soon as I put it in gear. Clearly my cleaning efforts disconnected something or got something wet, but for the life of me I cannot figure where even to look. It starts on the first pop, and dies as soon as the neutral light goes off. No apparent loose wires.
    Help.
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
  • oseaghdha
    • 1075
    • N43.02.5,W88.14.2
    You sprayed it with water, didn't you?
    Happens a lot on the SF.
    Don't worry, it will dry out.
    Do you, by any chance have a loose tach gasket?
    XS1100SF
    XS1100F
      Push in and out on the kickstand switch a few times... or is that only on the XJ?
      • Incubus
        • 1003
        • Austin TX
        No kickstand switch. Yes, I did spray it with water. I need to know what not to spray or where this might have happened. There is always a chance I will get caught in the rain. That would be a lot worse if the bike won't run in the rain....
        Patrick
        1969 Yamaha DT1B
        • Wildkat
          XS Special Gurette
          • Apr 2004
          • 3416
          • Location, Location
          Are you talking about a kickstand kill switch Tod?
          No such animal on the XSes... as far as I know anyway....
          Personally, I think he parked it next to Succubus too long... or the petcocks finally found this one...
          81 SH Something Special
          79 SF MEAUQABEAUXS
          81SH Nor'eas tah (Old Red)
          80 LG Black Magic
          78 E Standard Practice
          James 3:17
          “Alis Volat Propriis”
          Yamaha XS 1100 Classic
          For those on FB
          • Wildkat
            XS Special Gurette
            • Apr 2004
            • 3416
            With all the wiring going through the headlight... could you have loosened a connection somewhere?
            JAT
            I'm not good with the electrical stuff...
            79 SF MEAUQABEAUXS
            80 LG Black Magic
            James 3:17
            For those on FB
            • oseaghdha
              • 1075
              • N43.02.5,W88.14.2
              No, it's something that gets into the Neutral light circuit. I can't find it but the common symptom is that when you put it in gear it craps out. Mine did that first time I washed it. It did happen once when I left it out in a thunderstorm at work. Mine just drops 2 cylinders BTW.
              XS1100SF
              XS1100F
              • randy
                • Dec 2003
                • 4521
                It's the splice point inside the harness where the flexible cable is crimped to the harness. The neutral wire exits the harness there and water gets into the hole. Not really sure why it craps out when the neutral ground is disconnected, but we've seen that symptom come up quite a few times before. My theory (!) is that when the neutral light goes out, the neutral wire goes hot and fouls the signal to the TCI through the water.
                • Incubus
                  • 1003
                  • Austin TX
                  This actually comes as something of a releif. So far everything has gone well with this bike. I needed some part to fear and hate. Now I have one.
                  I think you might have a point, too, Kat. Incubus is parked only a short distance from Succubus at night. I think they may be talking. The lazy B is starting to show Incubus how to avoid work....
                  If it was the petcocks talking then Incubus would just run all the time and never shut off.
                  Patrick
                  1969 Yamaha DT1B
                  • Incubus
                    • 1003
                    • Austin TX
                    Ok, Incubus runs again. Two cylinders kick out sometimes, but they come back so I figure he's going to be OK. So what's the fix? Tightly wrapping the wires from the pickup coils in electrical tape? Sealing the wire in wax? Smearing asphalt on the wiring? I really want to be able to ride on days when it might rain. Or at least be able to wash it occasionally.
                    Thanks y'all.
                    Patrick
                    1969 Yamaha DT1B
                    • MrOzz
                      • Aug 2008
                      • 782
                      • Massachusetts
                      Thanks y'all.
                      Patrick
                      You could try liquid electrical tape. Stuff works well and not such a mess to clean off as with asphalt. lol
                      1980 XS 1100SG
                      Dyna 3 Ohm Hi Output Coils
                      Pod Filters
                      DynoJet Kit
                      T.C.'s Fuse Block
                      V-Max Auto CCT
