I've read the cam chain tip and followed the manual procedure for aligning the cams. The alignment mark on the exhaust cam lags behind about a degree or two. My question is if I'm in tolerance.
I've found top center using a degree wheel and piston stop.
I've aligned the indicator with the the T mark.
After following the manual procedure for aligning the cams and setting the chain tensioner the intake cam marks align very close.
The exhaust cam marks lag a few degrees.
Do I have more work to do here?
Even with a streached chain you could still adjust the cams alignments spot on
It would be much simpler to just follow the instructions, but it's turning out to not be that simple.
Are you sure about those factory specks
