head light search
  • boatdoctor
    • 31
    head light search
    Any One please help. i need the large rectangle head light for xs11 1978. Ican not find one oem or after market. has any body tired to modify one of these sealbeams with automotive light. some body please help me!
    Couple are on eBay. Or try member Andreas. The 78 is a sealed beam unit, but 79's and up use a replaceable H4 bulb. If you can find a 79 & up lens, that would be the way to go. Much brighter too.
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      If you find one with the replaceable H4 bulb you can put a H4 style HID bulb. Much brighter and less draw on the battery and charging system. If I remember correctly, 55/65 watts with the halogen. 35 watts with the HID.
      Ozz
      1980 XS 1100SG
      Dyna 3 Ohm Hi Output Coils
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
        Post you location and if someone is close they may help! The '78 had a sealed beam headlight, but the '79 and later standard have the H4 type headlamp. I would look for the the later model light! You CAN make a regular light work, but it will take some time.
        Welcome to the site!
        • mxmikie
          • Aug 2008
          • 482
          • Bouse az
          i have one if you still need one it takes the h4 bulb http://rides.webshots.com/album/574158441xeolWE
            When I got my MNS (round headlight), it had been modified to accept the sealed beam unit. I had to replace it shortly after I got it, and it was nice to be able to go to autozone and pick up a generic headlight for around $11.
