XS11 Carb interchange?
  • dragxs11
    • Jun 2003
    • 519
    • Reno, NV
    So I've only ever worked on 1980's. Now my neighbor has been given and 80sg with 78-79 carbs. We've got some obvious issues with the carbs, but what I don't know is whether early model carbs will run ok on an 80 engine.
    80's+ have milder cams right? so are we gonna have a mixture issue? Can I tune it out, or is the setup too radically different?
    matt
    1980sg-Stocker-- Sold
    1980sg- Cruise Missile- Sold to RODS454
    1990 ATK 604- Ditch Digger
    2005 BMW K1200S- Killer Bee
    2005 Suzuki GSX-R 1000- trackbike
    • 7737
    No problems with the carbs. I go back and forth all the time. Set them up as a '79 with float level and all, and just run. The mains are larger, as they supply the pilot jets as well.
    Have fun with it!
    • dragxs11
      • Jun 2003
      • 519
      • Reno, NV
      Thanks Ray...
      Hey, what are the extra t's and hoses for that go to the upper float chamber? Do I plug them, or leave them opened? Ray, I doubt you've ever seen carbs this messed up.... mostly human error!!
      • foreda
        • 949
        • Southwest Louisiana
        Carbs
        Originally posted by dragxs11
        Thanks Ray...
        On the 78/79 carbs the top hoses/tees connect to the air box. The bottom is where the hose connect from the petcocks.
        78 XS1100E Standard
        Coca Cola Red
        Hooker Headers
        http://i408.photobucket.com/albums/p...m/DSC00580.jpg
        1979 XS1100 Special
        http://i408.photobucket.com/albums/p...m/DSC00612.jpg
        1980 XS Standard
        http://i408.photobucket.com/albums/p...m/DSC01137.jpg
        2006 Roadstar Warrior
        http://i408.photobucket.com/albums/p...um/warrior.jpg
        • latexeses
          • Jun 2008
          • 1491
          • California
          The top tees are just vents.
          Everything on hold...
          • XSokieSPECIAL
            • Jun 2009
            • 1631
            • Tulsa, OK
            Yup, they're just vents. I have 79 carbs on my 80 special and they run good. I drilled holes in the ends of the nipples on the front of my airbox, they're still there to accomodate the earlier years. I had to play with the float adjustment to keep it from running too rich though. I'm set 2mm below stock settings for 79. Thinking of going lower, it's still a bit rich at low end.
            GT
            • dragxs11
              • Jun 2003
              • 519
              • Reno, NV
              Thanks fellas,
              Thats what I figured, just wanted to make sure.
              Also, Ray, thanks for the inadvertant tip on the pilot jets getting fuel throught the mains. I thought they werent used. Replaced all the jets last night. Had to get #15 pilots and drill them with a #78 bit. Standard practice anymore. So far I've found the diaphrams turned all wrong and one not seated under the cap. 2 pilot air needles busted off and jammed. clogged fuel lines, bad butterfly sync. and an insect nest in #2 bowl. I'm optomistic, after correcting all that, that it will run.
              • TomRodgers
                • Jun 2008
                • 492
                • La Porte Indiana
                Anybody live near Chicago (northwest indiana) that wouldnt mind helping me rebuild my carbs? ive never done it before, and dont want to screw them up!!!
                4:1 Jardine w/ headerwrap
                Windjammer(wiring issues)
                New paint/brakes to come!!
                '80G FrankenBike (parts bike)
                '80G to fix "BlackSunshine"
                Stock Pilots/125 mains
                Pod filters; 4:1 Kerker??
                SS Brake lines w/ new M/C's
                LED Brake Lite
                Needs paint....
