XS11 Carb interchange?
  • dragxs11
    • Jun 2003
    • 519
    • Reno, NV
    So I've only ever worked on 1980's. Now my neighbor has been given and 80sg with 78-79 carbs. We've got some obvious issues with the carbs, but what I don't know is whether early model carbs will run ok on an 80 engine.
    80's+ have milder cams right? so are we gonna have a mixture issue? Can I tune it out, or is the setup too radically different?
    matt
    1980sg-Stocker-- Sold
    1980sg- Cruise Missile- Sold to RODS454
    1990 ATK 604- Ditch Digger
    2005 BMW K1200S- Killer Bee
    2005 Suzuki GSX-R 1000- trackbike
    No problems with the carbs. I go back and forth all the time. Set them up as a '79 with float level and all, and just run. The mains are larger, as they supply the pilot jets as well.
    Have fun with it!
    • dragxs11
      • Jun 2003
      • 519
      • Reno, NV
      Thanks Ray...
      Hey, what are the extra t's and hoses for that go to the upper float chamber? Do I plug them, or leave them opened? Ray, I doubt you've ever seen carbs this messed up.... mostly human error!!
      • foreda
        • 949
        • Southwest Louisiana
        Carbs
        Originally posted by dragxs11
        Thanks Ray...
        On the 78/79 carbs the top hoses/tees connect to the air box. The bottom is where the hose connect from the petcocks.
        78 XS1100E Standard
        Coca Cola Red
        Hooker Headers
        1979 XS1100 Special
        1980 XS Standard
        2006 Roadstar Warrior
        • latexeses
          • Jun 2008
          • 1491
          • California
          The top tees are just vents.
          Everything on hold...
          • XSokieSPECIAL
            • Jun 2009
            • 1631
            • Tulsa, OK
            Yup, they're just vents. I have 79 carbs on my 80 special and they run good. I drilled holes in the ends of the nipples on the front of my airbox, they're still there to accomodate the earlier years. I had to play with the float adjustment to keep it from running too rich though. I'm set 2mm below stock settings for 79. Thinking of going lower, it's still a bit rich at low end.
            GT
            • dragxs11
              • Jun 2003
              • 519
              • Reno, NV
              Thanks fellas,
              Thats what I figured, just wanted to make sure.
              Also, Ray, thanks for the inadvertant tip on the pilot jets getting fuel throught the mains. I thought they werent used. Replaced all the jets last night. Had to get #15 pilots and drill them with a #78 bit. Standard practice anymore. So far I've found the diaphrams turned all wrong and one not seated under the cap. 2 pilot air needles busted off and jammed. clogged fuel lines, bad butterfly sync. and an insect nest in #2 bowl. I'm optomistic, after correcting all that, that it will run.
              • TomRodgers
                • Jun 2008
                • 492
                • La Porte Indiana
                Anybody live near Chicago (northwest indiana) that wouldnt mind helping me rebuild my carbs? ive never done it before, and dont want to screw them up!!!
                '81H (my first XS ) "Grey Ghost"
                4:1 Jardine w/ headerwrap
                Windjammer(wiring issues)
                New paint/brakes to come!!
                '80G FrankenBike (parts bike)
                '80G to fix "BlackSunshine"
                Stock Pilots/125 mains
                Pod filters; 4:1 Kerker??
                SS Brake lines w/ new M/C's
                LED Brake Lite
                Needs paint....
