can xs and xj tanks be interchanged as is, or do they need adapting? thanks
did the search, came up dry ... any help?
They will not interchange. In fact, the XS Standard and Special tanks will not interchange with each other either (without some modifications anyway).1980 XS850SG - Sold
-H. Ford -
Hi 'Bug,
to clarify that, The Standard and Special tanks themselves will interchange without being modified at all.
To get the Special's seat on with a Standard tank you have to crop the seat's nose or at least notch it to fit the Standard tank's fuel cap pocket drain tube connection.
I'd suppose putting a Special tank on a Standard would leave a gap there?
The fuel senders need to swap but only if you want the security of a gauge or a warning light because the senders work in different ways.
The gas taps have to stay with the tanks because they have different bolt centres.
Which means the Standard owner will have to either find a spare octopus or remember to turn the gas off.Last edited by fredintoon; 09-21-2009, 02:50 PM.Fred Hill, S'toon
"The Flying Pumpkin"Comment
Exactly... "Some modification". It's not a simple cut-and-paste.1980 XS850SG - Sold
-H. FordComment
In addition to the mounts, the fuel sending units are different and would need to be changed. Petcocks are not the same either, as the later ones are vacuum-operated in stock configuration and not all XSs have the "octopus" that the XJ and later standards(?) use. This can be changed / bypassed but does require some tinkering. Just a couple more things to consider.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
"... life is just a honky-tonk show." Cherry Poppin' Daddy StrutComment
