Alright so I have decided on how I am going to be doing my header pipes, and I wanted to see what all you guys though about this! I don't have a welder so I will be doing all this with some sort of bolt on solution...
First off I am going to be getting these baffles from eBay.
These I will be putting inside the end of my pipes.
As you can see I don't have much room, actually I have just over four inches of room to install these baffles. Thing are going to be TIGHT but at least these baffles will make things a bit quieter. The next thing I am going to be doing is installing Lollipops just behind the baffles at the bend. For those of you that don't know what a lollipop is, it is only the greatest exhaust mod on the planet!
It is pretty much a washer on the end of a bolt that you can adjust open or closed. It has TONS of fine tuning potential and is really simple to do. (Read more about it here)
Then finally after all that is done, I want to put a tip on it that will blow down and was thinking something like this...
Here is where I run into a problem...These tips cost well over $100 and frankly I am not made of money. So I am going to attempt to make them myself. The only question I have is what are the pipes made of? Stainless Steel or something else? This will be the only piece on my bike's exhaust that won't be wrapped so I kinda want these to keep their polish...Suggestions?
Other than that I was thinking of putting some kind of silencer (not sure if that's what it is called...) in the tip like the one in this video.
This I am going to try to fabricate, but don't know how that will go, so I may end up either putting a large fender washer inside the tips and drilling the other holes around, sort of like in the video, or just buying something from eBay.
Also I found this on eBay and might try this out. Anyone tried this fiberglass fabric stuff?
Thanks,
-Rick
Thanks,
-Rick
