Charging woes
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    Charging woes
    A while back I rode to/from Idaho. Had charging problems. Finances low and don't ride as much now so both XS's are parked.
    Yesterday my pick-up malfunctioned (wife drove it, happens everytime she drives it). Intermittent loss of power to ignition which caused backfires. One backfire blew my muffler apart. So, even if I get the truck running right I am still mufflerless.
    So I dug into the E. I had a feeling what the problem was and I was right. The 4 wire connector (3 white and 1 yellow) was melted. I marked, snipped, and reconnected the wires and it's charging again. Now to find a decent connector rather than the 4 individual connectors. Think a flat 4 prong trailer connectoer would stand the heat?
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
  • Ivan
    • Jul 2008
    • 2524
    • Hutchinson KS
    I think Geezer has a source fo rstock type connectors, might send him a PM
    Ich habe dich nicht gefragt.
      The problem is corrosion. If the connections are clean, there will not be ANY heat. I just soldered mine, but if you want to use a connector, as long as it's rated to carry the right size wire, it'll work.
      • tw1980
        • Apr 2009
        • 662
        • Bend OR
        I can personally vouch for geezer's connectors.Just make sure if you use them you follow his crimping instructions.
        Terry
        1980 special (Phyllis)
          Terry
          Hi Terry,
          yeah, my 4-way melted a while back and I'm currently operating on 3 crimped on bullet connectors.
          (The SG's yellow wire just goes into the 4-way but it stops right there.)
          Do Geezer's crimping instructions involve using a good crimper instead of the $2 bent sheetmetal thingie that came with the crimp connector kit?
          • Geezer
            • May 2003
            • 2985
            • Willamina, Oregon 97229
            Check out these pages.
            Yes the Wing on the second page is mine. In my defense, I bought it that way...
            Geezer
