Bob - The first thing we did after changing the mechanical advance for a plain rotor was to sync that puppy, which is where I noticed the somewhat low vacuum readings. I got them all closer than 2cm of vacuum, so the sync should be good.
AAAAAARRRRRRGGGGGGG!
I agree with you that just advancing the timing wouldn't cause all these woes. I'm thinking that, whatever is advancing the timing, may be causing other problems too. Where's the boost sensor located on an '81 SH? I only saw one vacuum line coming off #2 and going to the vacuum advance. The octopus has been removed, so the carb boot taps are all plugged. I think Don wants to get back into the carbs anyway as he evidently didn't get into the tops on the last go around.
Part of the problem is that we only get our hands on this machine intermittently, and when Varnae brings it over here he has to trailer it all the way from Indianoplace - a little over 100 miles each way. I'm trying to get all the ducks in a row 'cause I'm hoping the next time he brings it over will be the last time. I certainly respect your opinion on carbs, but I'd still like to have a TCI handy - just in case.
One other thing that bears mentioning - it appears someone has had the carbs off the rack at some point. I say this because the ball bearings that hold the choke open are missing. I don't know how it was running before it knocked the head off a valve and trashed the first engine - have to defer to Varnae on that. He said it was still running with a 2" hole in the top of the #3 cylinder afterwards, whatever that tells us
. Anybody know what size those ball bearings are?
Looks like the next time we get our hands on the 'demon spawn' is going to be October 3rd. I should probably say the skydiver's prayer prior to touching it - "Oh God, please don't let me f*** this up."
the boost sensor's job is to RETARD the timing during high load / low vacuum conditions. One more variable for you !
