Seat problem..........
  • Giggity
    • Mar 2009
    • 113
    • Longmont, CO
    I have a '79 standard and am having problems getting the seat to properly secure. The tongue on the seat pan does not want to stay in the securing slot once it is tightened down. When I sit on it, the front of the seat will slide from side to side. Any way to fix this?
    1979 XS1100 Standard
    Putting it together........
    • 1377
    The tongue slides into the front part..."shoe".
    On My bike the "shoe" has a piece of rubber which fits inside the metal part.
    Is the rubber piece present in your setup?
    • Giggity
      • Mar 2009
      • 113
      • Longmont, CO
      Yes it is.
        • 1377
        Lock it in
        Cool! Then if the rubber piece is present then the movement at the front of the seat is likely that the problem is with the tongue.
        The tongue is riveted to the bottom of the seat pan. If the rivets are broken or loose this will let the tongue wobble. (repair/replace rivets...)
        If the tongue is bent down too low then it will miss locking in to the shoe at the sides and allow the wobble. (bend the tongue UP towards the bottom of the seat pan. Do NOT put the stress from this bending process on the rivets themselves!! DAMHIK!)
        • foreda
          • 949
          • Southwest Louisiana
          Bend your tongue
          You going to have to say ahh and bend your tongue. It bends pretty easlily.. easy fix.
          78 XS1100E Standard
          Coca Cola Red
          Hooker Headers
          1979 XS1100 Special
          1980 XS Standard
          2006 Roadstar Warrior
          • Giggity
            • Mar 2009
            • 113
            • Longmont, CO
            got it figured out!
            Thanks for the help.
