Indicators, LED bulbs
  • ozlad
    • 42
    • Mackay,Queensland,Australia
    I just changed my bulbs to LED, changed the relay to an LED relay and all works fine until I start the bike. Then it is like a disco(showing old age ,lol) with the blinkers going ten to the dozen, fast and slow. Turn the bike off and all is well. When I looked at the wiring plug to the relay it is 3 wires and the PO had a 2 wire relay. I can't get a 3 wire relay to work at all and can't find any self cancelling relay, in it's place is an ignition relay. Also the wiring diagrams in my Clymers and the one I downloaded from CatotonicBug seem to be different to our Aussie bikes. Any suggestions greatly appreciated
    '81 XS1100R
    4-2-1 exhaust Tranzac (Current)
    Everything else stock (as far as I know)
    Previous:
    Honda scrambler horse( had to start somewhere)
    Yamaha DT175
    Yamaha XT250
    Yamaha TT500
    Suzuki DR250
    Yamaha XVS1100
    Honda 750/4 K (basket case, current)
  • mxmikie
    • Aug 2008
    • 482
    • Bouse az
    if you use your stock flasher and install a set of load resisters they will work http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
      Hey MXMikie,
      That TOTALLY defeats the purpose of going to LEDS on these machines. The charging system puts out very little extra power, and using LEDS helps to cut down on the current draw by several amps, but using load resistors just puts the draw back in the system.
      Hey Ozlad,
      You say you put on an LED Relay?? DO you mean an Electronic Flasher Relay specifically designed for use on systems with LED lights...or what?? Does it say Electronic on it??
      We don't have access to the wiring diagram for your specific machine!
      However, LED's require very little power to work, and IF there is any current bleeding into the system/turn signal circuit, it can cause havoc! Also, do you have 1 turn signal INDICATOR on your dash, or 2 for left and right??
      IF 1, then you are getting current bleed thru via the Indicator light, and you need to put on a couple of DIODES in line from the left and right turn circuits as they go to the Indicator light, so that the current will only go to the dash light, and not down the wire to the other side/set of turn signals!
      • ozlad
        • 42
        Hi TC It is a LED flasher unit, for use with LED Bulbs. I did try an electronic flasher but it was really slow on the dash it is the same as your special's, 2 lights for left and right... somebody did mention awhile ago, think it might have been Steptoe, that the wiring is the same as a XS1100 Sport (5K7) if my memeory is correct but I can't find where to download it from. I am going to trouble shoot a lot more tomorrow, hope fully it will be something simple..... only havoc is caused on what ever side is 'spose to be flashing.... no bleed to other side and only when bike is running
        '81 XS1100R
        Previous:
        Yamaha DT175
        Yamaha XT250
        Yamaha TT500
        Suzuki DR250
        Yamaha XVS1100
        • ozlad
          • 42
          Problem fixed!!!!!!! Turned out to be a faulty relay.
          '81 XS1100R
          Previous:
          Yamaha DT175
          Yamaha XT250
          Yamaha TT500
          Suzuki DR250
          Yamaha XVS1100
          • Shappers
            • Sep 2006
            • 158
            • Helsinki, Finland
            Glad you fixed it.
            The colour wiring diagram is HERE. And you're correct, the 5K7 Sport model is the same as your 5N5 model so the wiring is the same.
            '84 Sport
            • ozlad
              • 42
              Thanks Shappers but the link won't work
              '81 XS1100R
              Previous:
              Yamaha DT175
              Yamaha XT250
              Yamaha TT500
              Suzuki DR250
              Yamaha XVS1100
              • Shappers
                • Sep 2006
                • 158
                • Helsinki, Finland
                Works for me
                Try right-clicking it and select Save-as...
                If that doesn't work, PM me your email address and I'll attach it to an email..
                '84 Sport
                • ozlad
                  • 42
                  Seeing as how you put it that way..... works for me too, now
                  '81 XS1100R
                  Previous:
                  Yamaha DT175
                  Yamaha XT250
                  Yamaha TT500
                  Suzuki DR250
                  Yamaha XVS1100
