is anyone running an automatic cam chain tensioner ?
  • newtoXS11
    • Jul 2010
    • 29
    • Green Bay, WI
    I was curious as to how well this is still working. Any update?
    • Cobia
      • Jul 2007
      • 1587
      • Palm Beach County, Fl
      Automatic Tensioners
      Het New,
      I put mine in about 400 miles ago, w/out any modifications, and so far so good. In fact it actually quieted the engine down a lot. I had to use the original bolts, instead of the vmax ones, because they are the right length.
      BTW - Did it on the centerstand, plugs out, turned engine twice through the C mark then right on it. After installed, we turned the engine, by hand (plugs out), very carefully through four revolutions to make sure there was no binding or potential for bent valves.
      Yeah, I know, risky but there should be no prob with this procedure if you take your time and ease everything in and out........ OK, OK
      The increase in gonad size when doing this was directly proportional to the pucker factor experienced during the final turning of the engine. Particularly when pushing the starter button.
      1980G Standard, Restored
      Kerker 4 - 1
      850 Rear End Mod
      Automatic CCT
      1980GH Special, Restored
      '82 XJ1100 (Sold)
        Cobia is correct......DON'T use the allen bolts that would go with the Venture self-tensioner! The bolt holes ARE bottom holes and those bolts are too long.
        • nutwister
          Xsive
          • Jul 2010
          • 38
          • Planet Earth
          Original Thread
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            The vventure adjuster on my E is working fine for the last couple of weeks. The XS allen bolts were slightly long. Two washers solved that problem.
            Now to sterilize the other venture adjuster and paint it black for the LG.
            Pat Kelly
            <p-lkelly@sbcglobal.net>
            1978 XS1100E (The Force)
            1980 XS1100LG (The Dark Side)
            1999 Suburban (The Ship)
            1994 Dodge Spirit (Son #1)
            1968 F100 (Valentine)
            • yamahansolo
              • Aug 2007
              • 1113
              • jawga
              I have been using my vmax tensioner for about 6 months or so and it's great!!! Plus no need to modify.
              79 xs11 standard
              8mm msd wires
              tkat fork brace...
              Fox shocks...
              mikes650 front fender
              led's gallore...
              renthal bars
              gold valve emulators
              vmax tensioner
              Rifle fairing
                I have the Venturer 1300 on mine. No problems at all.
