Where is the fluid return on the rear master?
  • Incubus
    • 1003
    • Austin TX
    Incubus the XS11 project is ready for a run around the block to check out the clutch and potential second gear issues. Before I can do that, however, I have to unlock the rear brake. The master works - it builds up pressure and stops the wheel, but it does not release properly, leading me to believe the master is not allowing the return of fluid.
    I just changed the back tire and when I did I compressed the brake piston completely. When I put the wheel back on the wheel turned freely. As soon as I pumped the back brake back up, though, it grabbed the rotor and won't let go. Those are my total symptoms.
    Suggestions are welcome.
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
    An easy way to determine if the caliper or the master cyl. is causing the problem is....
    Loosen the bleeder screw, don't snap it off . If the wheel spins now, the master cyl. spooge hole is plugged. If it still doesn't, the caliper seal is gunked up. Remove and clean the appropriate part(s). The fluid return is the spooge hole.
    • Incubus
      • 1003
      • Austin TX
      Where is the splooge hole on the rear master? I can't find any small holes like the front master has.
      1969 Yamaha DT1B
      • Montreux_Blue
        XS-XJ Guru (Deceased)
        • 1143
        There are pictures here -
        Famous Myspace quote:
