Problem is, Bondo will not hold up to 400 F degrees. I was considering Lab Metal but would like a choice.
I thought the big thing was it needed to be metalic so a current can pass through it?
and it should hold up for what I’m using it for. If the muff’s get to 500 degrees I don’t think I’ll be worry about the JB bondo job.
I also got a stainless steel screw set for all the cases and covers. I put the oil pan ones on too since they were in the set. Yup... pretty much pointless also! lol.
. Ground down the real bad rust pits some, then used files to get it a little closer, Entire surface (including muff’s) sanded with 80 grit sand paper, then 100 grit.
) I would take em to a powder coater and have it done with their high temp coating. There are some that can handle 1,000 to 1,200 degress now.
