Has anyone used this type guages?
  • furious4
    • Jun 2009
    • 80
    • St. Cloud Florida
    Tommorrow I'm going to attempt to synch my carbs. I resently installed new carb boots and cleaned up the carbs a bit so figured it would be a good idea to synch them. I read the tech tips on doing the synch. what I was wondering is if anyone has used this type of guages my friend has lent me? Looks like I just hook up the hoses but all those attachment scare me and are the dampeners built in? sorry if this sounds stupid but I just want to do it right . I rarely do things right the first time
    1980 Midnight Special Its so fast it blew the gold right off
    mikes xs green monster coils, ss brake lines,
    Previous Bike
    1973 XS650
  • Ken Talbot
    • 4251
    • Revelstoke, BC
    Those should work fine, even if they do look a bit intimidating. All you're really trying to do is get a gauge attached to the vacuum nipple on each of the manifold boots. I'm not sure where the dampeners are, but somebody will probably step in soon to confirm that for you.
    Note - in your photo, all four gauges are sitting with different readings. A ket part of the sync process is making sure all of your gauges read the same anout for the same amount of vacuum. Without that assurance, you'll be chasing your tail. Somebody more familiar with this type of gauge will need to tell you how that gets done.
    Ken Talbot
    • Silent
      • 343
      • San Jose, CA
      I've used those guages in the past, and while they do work, the do not work nearly as easy as a mercury manometer (carb stick). The key to getting those guages to work proper is to use the restrictors in-line to limit the bouncing of the needles, and synch all 4 guages off of the same vacume port before hooking up all 4 guages to all 4 ports. Attatch the first guage to port 1 and take a reading. Unplug that guage and plug in #2 guage in the same port without touching anything on the bike and adjust it so you have the same reading as guage #1. repeat with 3 and 4. Then hook em all up and you should be able to adjust your synch properly.
      Ray
      '79 XS1100 Special - An XS Odyssey <<-- Click it, you know you want to!
      '07 FJR1300
      • furious4
        • Jun 2009
        • 80
        • St. Cloud Florida
        guages
        Thanks so much. the reason I'm using this set is because my friend got them with his mc and he let me try them out.he never used them so thanks for the tips
        Previous Bike
        1973 XS650
          • 1377
          Love at first Synch
          I used a similar style but different make of gauges.
          Just turn the dampener knobs down until the needles stop jumping around. Also very important to make sure all gauges read the same amount when connected to a single vacuum source.
          Gauges are an end to the means here. A superbike with four synched carbs will accelerate like it means business.
          Enjoy!!
          • aussixs11G
            • 76
            • Brisbane Australia
            own 'em - use 'em
            the gauges shown by Larrym are the same as mine and are easy to use and cheap to buy
            Bryan H
            "Conan, what's best in life?"
            "To crush your enemies, drive them before you and the lamentation of their women"
            • dbeardslee
              • Nov 2007
              • 4385
              • Maineville, OH
              Gauges work fine, but as Silent mentioned, they need to be calibrated. Putting them on the same cylinder (and at the same rpm) works, but what works even better is attaching them, one at a time, to a power brake bleeder that has its own gauge. On mine I pumped the bleeder up to 10 inches of vacuum, which is close to 22 cm of vacuum, which is about what the carb boot taps should draw at idle. Make a notation of differences, and then take 'kentucky windage' when syncing. To be properly synced all carbs need to be withing 2 cm of vacuum of each other. Also, don't adjust the dampeners down to the point where there is no bounce in the needles - they need to be moving a little bit so you know you haven't completely shut off the dampener. My $.02
              • furious4
                • Jun 2009
                • 80
                • St. Cloud Florida
                Thanks everyone
                I was able to get my carbs synched today. Just wanted to say thanks for the help I recieved for all who replyed and the great tech section.
                Previous Bike
                1973 XS650
                  • 1377
                  Dampened Spirits
                  Cool!
                  And just where were the dampening adjustments on your style gauges?
                  • furious4
                    • Jun 2009
                    • 80
                    • St. Cloud Florida
                    dampeners
                    Air flow control is handled by needle and seat valves instead of knobs located below the guages right were you hook the tubes up. just had to move them around to control the bounce.
                    Previous Bike
                    1973 XS650
                    • Silent
                      • 343
                      • San Jose, CA
                      Good to hear you've gotten it working propperlty. Glad I could be of service.
                      Ray
                      '07 FJR1300
                      • digitalsam
                        • Aug 2008
                        • 208
                        • Carlsbad, NM
                        Just thought I would post a picture of my home made gauge. It worked well and only took a short time to sync. The hardest part was getting the two pairs to sync after I had sunc (sp?) 1 to 2 and 4 to 3.
                        I don't know if they are better or worse than the gauge type, but they are cheaper and really I was just looking for a place to post my handiwork.
                        Here it is running after I synced (sp?) 1 and 2.
                        Sam Christensen
                        The Chronicles of my Rebuild http://xs1100rebuild.blogspot.com
                        If you are leading and no one is following, maybe your just taking a walk.
                        Currently bikeless. Sold my 1980 XS1100 Special
                          • 1377
                          En-Gauged!
                          I Like it.
                          Something tells me that I wouldn't be able to find a label with the words:
                          "Heche en Mexico"
                          "Product of China"
                          Looks like you used a totally closed loop/system instead of a separate vent tube. A separate vent tube might make the fluid response more sensitive and lead to a "closer" synch between the carbs. It also might allow the fluid to get sucked into the engine.
                          Be sure to put "Made In The USA" on it somewhere.
                          • digitalsam
                            • Aug 2008
                            • 208
                            • Carlsbad, NM
                            Que es un (what is a) separate vent tube?
                            A survey in Texas found that 29% thought that there was an imigration problem. 71% responded "No es un problema."
                            Sam Christensen
                              ?lo siento pero que es 'vent tube'? !no entiende!
                              Saludos,
                              eScott
