Carbs Adjustment Tool
  • digitalsam
    • Aug 2008
    • 208
    • Carlsbad, NM
    Alright, I added a 1/2 tsp of gas to the #1 cylinder through the spark plug hole and varoom, it started up. It's Alive! muh haa haa!
    Then I attached my makeshift carb sync tool (Pix later) to the ports on the carb boots.
    Qeustions 1: I cannot keep the engine running without holding the throttle, how do I fix that or what causes it to die without the throttle pulled? Is it just adjusting the throttle knob under carbs or could it be more?
    Question 2: I can sync the carbs at 1000rpm but they are then out of sync at 3000 rpm. Is that supposed to happen or is there another issue I should be dealing with.
    Question 3: When is someone going to move to Southeast NM so we can get together and fix my bike?
    Sam Christensen
    The Chronicles of my Rebuild http://xs1100rebuild.blogspot.com
    If you are leading and no one is following, maybe your just taking a walk.
    Currently bikeless. Sold my 1980 XS1100 Special
  • Silent
    • 343
    • San Jose, CA
    1: Turn up the idle screw between the carbs and you can keep it running.
    2: Don't worry about the synch running out at 3k, its normal.
    3: No help from me there, but you're welcome to come out here
    Ray
    '79 XS1100 Special - An XS Odyssey <<-- Click it, you know you want to!
    '07 FJR1300
    • digitalsam
      • Aug 2008
      • 208
      • Carlsbad, NM
      Silent, You should reconsider. Carlsbad may be small, dusty and remote, but it's hot and um. well. We do have the Carlsbad Caverns.
      OK, I adjusted the idle (a little too high at first) and took the bike out for a spin. At first it was very sluggish and died within a half mile. After a minute, I got is running again (no adjustments, just the starter and throttle) it seemed less sluggish so I took it out a little further. About three miles out it started sputtering and dies again. This time I had to let it set a while before it would restart. Brought it home and here I am. Any thoughts on the dying and sluggishness?
      By the way, that bug avatar is creepy. I keep wanting to swat my screen.
      Sam Christensen
      • Silent
        • 343
        • San Jose, CA
        It's only there to 'bug' ya
        Sounds to me like you need a good cleaning of the carbs. Maybe run some SeaFoam with the gas to help clean out those itty bitty passages.
        Ray
        '07 FJR1300
          • 8672
          Check your plug color. White: not enough fuel. Black: too rich. Are you running the octy? If so, try running on prime. Make sure no fuel lines are kinked.
          • digitalsam
            • Aug 2008
            • 208
            • Carlsbad, NM
            Ok, they are a dark brown. I am guessing it is too rich. How do I fix it?
            Sam Christensen
              • 8672
              Carbs are probably dirty as stated before. Try the Seafoam first. What's the condition of your air filter?
              • digitalsam
                • Aug 2008
                • 208
                • Carlsbad, NM
                Brand spankin new K&N air filter. So I need to fill the tank, add seafoam and ride it a bit?
                Sam Christensen
                  • 8672
                  Half a can of Seafoam to a half a tank of fresh gas should be good. Ride it a few miles and let it sit overnight, then see if it's any better.
