Greetings Fellow XSives,
I am currently in the process (LITERALLY!!!) of upgrading to the Mike's XS Green Performance Coils. Things were moving along swimmingly, thanks to the wealth of information available on this site (Thank you all).
After reading many posts on the subject, I ordered the following from Mike's:
XS Performance 3 OHM Dual Coil - Part # 17-6810
XS Perf. yellow silicone Plug Wire Set - Part # 23-2906
NGK Plug Cap - LB05FP 5k Resistor - Part # 23-3113
The coil installation went smoothly using the right angle bracket modification mentioned in other posts.
The issue is the spark plug does not snuggly sit in the caps. Am I missing something, or do I have the wrong caps.
Thanks in advance,
Thanks in advance,
Safe riding,
