Spark Plug/Resistor Cap Question
  • chuckditta
    • 44
    • Sarasota, FL
    Greetings Fellow XSives,
    I am currently in the process (LITERALLY!!!) of upgrading to the Mike's XS Green Performance Coils. Things were moving along swimmingly, thanks to the wealth of information available on this site (Thank you all).
    After reading many posts on the subject, I ordered the following from Mike's:
    XS Performance 3 OHM Dual Coil - Part # 17-6810
    XS Perf. yellow silicone Plug Wire Set - Part # 23-2906
    NGK Plug Cap - LB05FP 5k Resistor - Part # 23-3113
    The coil installation went smoothly using the right angle bracket modification mentioned in other posts.
    The issue is the spark plug does not snuggly sit in the caps. Am I missing something, or do I have the wrong caps.
    Thanks in advance,
    Chuck Ditta
    ________________
    1983 XJ750MK
    2008 HD FatBoy - My experiment with the dark side!!!
    1980 XS1100LG (Donated to a friend (and lifelong XS'er) in need)
    K&N Air Filter
    Mike's XS "Green" Coils
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    chuckditta,
    The plug cap you have is for For terminal stud. If you did not already do so remove the top part of the spark plug. All it does is unscrew. There you will see the stud. Then atttach your spark plug cap.
    Hope that helps,
    Ozz
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
    • chuckditta
      • 44
      • Sarasota, FL
      Ozz,
      Thanks a bunch. That was it.
      There's no substitute for experience!!!
      Chuck Ditta
      ________________
      1983 XJ750MK
      K&N Air Filter
      • tw1980
        • Apr 2009
        • 662
        • Bend OR
        Don't forget to remove the resister and I like to dab a little antisieze on the plug threads and on the top of the plug.Also many here will say I'm crazy but I use the iridium plugs also.
        Terry
        1980 special (Phyllis)
        • MrOzz
          • Aug 2008
          • 782
          • Massachusetts
          Originally posted by chuckditta
          Ozz,
          Your welcome. Safe riding,
          Ozz
          1980 XS 1100SG
          Pod Filters
          DynoJet Kit
          T.C.'s Fuse Block
          V-Max Auto CCT
