Mounting a used tire - help, no dot
  • Incubus
    • 1003
    • Austin TX
    A friend gave me a real nice used Dunlop that he had left over when he upgraded to Pirellis. It's about a year old with less than 1,000 miles on it. After I got the first bead on (RuGlyde is amazing stuff. It's like mounting a bicycle tire) I discovered that the alignment dot that goes next the the valve stem is no longer visible. Can anyone tell me how to properly align this tire or, alternately, how important that is?
    Thanks,
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
    Patrick,
    The dot is to minimize the weight needed to balance the tire. The valve stem us USUALLY the "heavy" side of the rim, and the dot would be the "light" side of the tire. That is ALL it's for, so you may just need a little more weight to balance it.
      Heck, with that RuGlide on there, run axle thru it on a couple blocks, then could slip tire around on rim having no air in it to set the bead untill it took least amount weight.
      • wa407mpp
        • Jul 2007
        • 717
        Look for a small molded in arrow pointing toward the rim.
        Fastmover
        lion". SHL
        78 XS1100e
        • wa407mpp
          • Jul 2007
          • 717
          front or rear?
          Are you mounting a front tire or a rear tire? if it is the rear the bead locks should balance out the valve stem, so it shouldn't make much differance how you mount it on the rim.
          Fastmover
          lion". SHL
          78 XS1100e
          • MindWebs
            • May 2009
            • 431
            • Baldwin, WI
            easy does it..
            i think what people are trying to say is that it doesn't matter if there is no dot to line up.
            Just be sure to have the tire balenced, so that it won't vibrate.
