final drive leaking
  • tw1980
    • Apr 2009
    • 662
    • Bend OR
    final drive leaking
    It's leaking around the oil seal Idem #27 on parts diagram.Do I have to remove the bearing housing to replace the seal or can I just carefully pry out the old seal and tap in the new one? Thanks
    Terry
    1980 special (Phyllis)
    1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod
    IF that seal is even still available, it'd probably be cheaper, and DEFINATELY easier to just pick up another final drive. If you have the stock final drive, some of these guys that have done the 750/850 swap may have one cheap. Might be a good time for you to try one of those out also...?
    Either way, I'd personally just replace the final drive. if you're sure it's not just grease getting slung out, or your vent tube spewing it a bit
    • tw1980
      • Apr 2009
      • 662
      • Bend OR
      12.99 @ Bike Bandit.I like the lower gearing
      • tw1980
        • Apr 2009
        • 662
        • Bend OR
        Anybody???
          • 8894
          There is a link in the thread below for the final drive service manual in PDF. HTH. It appears to be just a tap in seal, so my guess would be that the unit would not require dissassembly. Good luck!
            Hmmm.. And how many people have said that before until they actually tried one..
            Your choice of course, but after a day or two, you'll never notice anything different on the bottom end, but you'll sure notice better cruising speed rpm. I don't see how anyone could LIKE the revs the motor is doing at 70-75 mph for hours.
            • tw1980
              • Apr 2009
              • 662
              • Bend OR
              http://www.xs11.com/forum/showthread...t=shaft+manual
              Thanks Phil
              • CatatonicBug
                • 6117
                • Clinton, UT
                Thanks for that! I didn't even know that existed! If you know of any other "special" manuals like that, let me know. I'll be adding this one to my website today.
                • tw1980
                  • Apr 2009
                  • 662
                  • Bend OR
                  Easy!!
                  Carefully pry out old seal.Grease inner and outer of new seal.Tap into place.Check fluid level and refill as needed.Done!20 minute repair.Just like replacing axle seal in my old 1/2 ton chevy.Reassemble real wheel and brake.
                  Terry
