I replaced the right hand handlebar switch, on the 78E with one from a newer model, w/o the headlight on/off switch.
The hookup had six wires, the newer switch has 4. I was able to figure out the 4 I need for the bike to start, and the kill switch works.
Just need to know if I need to join the two left over wires, or is there another way to get the headlight to work?
Unless... Is your Red/Yellow hot w/key on? It should be as it's supposed to be coming straight from the fuse block.
